Baader Maxbright II binos - is there a way to lock the IPD setting?
3 replies to this topic
#1 PilsnerDk
PilsnerDk
  • Loc: Denmark
Posted 17 March 2025 - 08:07 AM
Hi, I'm the otherwise happy owner of a pair of Baader Maxbright II binos. They are great and I love binoviewing, but one of the major things that bother me that the way you always lose the IPD setting in the dark when messing with the bino. I can't read the IPD scale in the dark, so it's hard to get back on track. It's typically when changing eyepieces or when turning it to adjust the angle that they get out of adjustment (I use a dobson, so I have to often adjust the binos to match the new altitude angle).
It would be awesome if there was a screw somewhere to lock it, or perhaps one could manufacture a piece of metal or wood to lock in the IPD setting.
#2 wrvond
wrvond
  • Loc: Leon, West Virginia
Posted 29 March 2025 - 09:45 AM
The answer to your question is "no", there isn't. I experience the same thing with my Mk V BV. I simply readjust the BV IPD until the image merges.
#3 noisejammer
noisejammer
    Fish Slapper
  • Loc: The Uncanny Valley
Posted 01 April 2025 - 09:22 AM
I find it's easiest to keep the exit pupil a little larger than when I'm using one eye. The larger ep makes it easier to capture the images simultaneously and then you can tweak the IPD. Remember, at high power, a tenth of a millimetre matters.
Typically, I don't use an ep of less than 0.65 Sitting at the scope helps greatly.
#4 denis0007dl
denis0007dl
    Binoviewers Expert
  • Loc: Umag, Croatia, Europe
Posted 01 April 2025 - 09:36 AM
Hello PilsnerDk,
I know the answer, but did you contact Baader first?
Kind regards,
Denis
