I like it Bob !
If I were coating silver as a business, such a setup would make sense.
But, at least for this poor ATMer, even the AG pump-up sprayers were a bit rich for my blood.
So I started out using what I knew, the typical pump-up weed sprayer, which i might add, looked suspiciously like the official AG sprayers.
My coatings kept getting better as I learned from experienced folks like the OSW group, especially Howard and Mel.
Add to that my 6 or 8 attempts to date, and i began to get very good coatings, except for my ever present nemesis, the dreaded blue haze. In desperation i started looking more closely at my process, and all the notes i had taken from the experts i talked to. Having a pile of window pane glass in my shop, i started changing things one at a time to try to discover where the haze was coming from.
Rob at OSW and I were discussing what the haze actually is, with suspicion it's early/uncontrolled growth of excess silver crystals on the glass, which seemed likely seeing as how i could wipe it off if done immediately after spraying, which was OK for small pieces and test glass plates.
But try as i might i could never get it all off before it (apparently) "set" on larger pieces like my 17.5" BT mirrors.
Finally i noticed that the nozzles on my garden sprayers, even when pumped up well, though producing a fine spray, had a few little coarser "squirt streams" here and there in the otherwise even spray cone.
That led me to wonder if i was getting enough local inconsistency in the spray cones to disrupt the 1:1 ratio needed for the Silver and Reducer sprays to work according to the AG chemistry requirements.
I was very carefully measuring my S & R solutions, but was I negating all that care by spraying the solutions at an uneven ratio ?
Of course I calibrated the S & R sprayers for equal volume per time, but could there be local inconsistencies in the actual spray cones which negated all that care ?
Such local inconsistencies would be missed by a simple spray volume vs time calibration.
With that in mind, i started looking at other sprayers, with a goal of getting the finest, most consistent spray cone possible, with no local inconsistencies visible in the spray.
I have a compressor & gun setup for spray painting which satisfies that, but as they say, water and oil (nor paints ! ) do not mix, so i was loath to be running the AG chemicals thru that system, not to mention i'd need a second sprayer setup .
After trying several different wands and tips on the garden sprayers i had been using, I came across these little 48-oz pump up sprayers. Testing with water, I was happy to find I could get a beautifully fine & even spray cone if i cranked the tips in tight and pumped the bottles up 100X.
So with two of those in hand, I mixed a small batch of the AG chem's at a thin (54:1) ratio, cleaned a piece of window glass, and gave it a shot. To my delight the coating went on beautifully even, developing slowly to a bright silver, with no trace of my dreaded blue haze, an enormous first for me !
After that I silvered a 4.25" Secondary for the BT and a 4" flat for a folded frac project.
Both came out 100% perfect, very bright, & zero Blue Haze !
I have not re-done the 17.5 pair yet, but now at long last,
i am confident i can get a perfect coating with no haze.
For anyone wanting to try them, the little sprayers I used are Chapin #1002, 48 oz, White bottle with red pump top.
Our local BiMart has them for $13, often on sale for less. Way easier to handle, no hoses and wands, no hand trigger spraying. And the price is a final bonus
Best,
Bob
Edited by Bob4BVM, 18 March 2025 - 07:44 PM.
