Interesting. Would it still be possible to see some examples though? I recognize the difference in person versus through a video can be drastic, but I would still like to see some examples.
Its hard to visualize that in a picture. It also depends a LOT on what elevation angle you look at things. So near the zenith the differences are small, but if you look at something deep down south near the horizon, the difference can be several magnitudes in extinction. I once viewed the southern cross from Haleakala at 10,000 feet and it was bright and seemingly "well above the muck". The next night, from sea level, I could barely see one star down there. The marine layer was to blame a lot for that as well.
But (there is always one, right) there is a limit for visual observation: Once your blood oxygenation levels start to drop, visual acuity and sensitivity are measurably affected. How much depends a lot on your physical condition and adaption to higher altitudes. As a rule of thumb - around 8000 feet it starts for some people and by 12000 feet almost all people have measureable issues, short of those staying for weeks at these elevations. Dark adapted sensitivity seems to degrade before you feel other physiological effects in thin air. https://pubmed.ncbi....h.gov/24479261/ and many other references there.
So that is why the general saying is - going from sealevel to 3000 feet gets you above the worst of the muck, 5000-8000 feet may be ideal for visual, above that it starts to depend on you more than the sky.
Edit:
I found an old geeky table I did to get some idea how much elevation vs altitude matters. To answer to myself "do I better drive another 300 miles south or up a higher mountain instead" when trying to see the southerly goodies.
It tabulates atmospheric extinction (in astronomical magnitudes) as a function of elevation angle and observer altitude, based on airmass data only. Its kind of a minimum change you see if your skies are completely void of any moisture or dust all the way down to where you want to observe. A somewhat theoretical thing, as the actual atmosphere has moisture and dust in a (highly variable) layer close to the ground. So getting "high enough" so your actual line of sight goes just above that is a much bigger factor.
From the outlined boxes you can see that at sealevel, you loose a full magnitude at 15 degrees elevation.
But at 5000 feet you can get that same extinction down to 10 degrees elevation. So you can access "5 degrees more sky" in comparison up there.
Edited by triplemon, 19 March 2025 - 01:05 PM.
