Hi all, came across this $60 USB-C chillers, that can attach with a magnet plate. I got 1 for my ASI ZWO 178MM, and inside seams to cool down to 25 F degrees. Not bad for $40 on Amazon.
Then I found a smaller unit and cools better, it's $60, they are made for cell phones and ipads. This is the 1 I got and I am very surprised with the size as it's very small about the same diameter as the ZWO 178MM, and with the stick on magnet thin mask. It's blue tooth so you can control the cooling and can change the RGB led's colors. It says it can show the temperature, but I am not seeing it as it's in the Android app.
Here's the link and just wanted to let others know about this is someone is looking to cool there non cooling cameras.
https://www.amazon.c..._fed_asin_title
When I can get the app to show temps, this will be great!!!
Christopher
