I'm the recent owner of an AM5N. While I will eventually start using it for AP, it's first purpose will be as a portable visual rig. My only major issue on that front is the accuracy of the goto system. I've read conflicting reports on how well the multi-star align is supposed to work, and was wondering if anyone here had managed to make it work reliably well. The tracking is excellent, easily holding a planet centered in even a very high power FOV for a very long time, but I've found the goto to just be completely off... Even slewing back and forth between Pollux and Castor, after having synced to both, only works on occasion. Anything further and I'm always off by multiple degrees. Has anyone managed to make it work reasonably well ? I'm not asking for arcminute accuracy, but I'm multiple degrees off even when slewing back to a star I just synced to. Granted I've just played around with it for one night, so there may be things I'm doing wrong. Here are 2 things that maybe I can improve :
- Better leveling : the new version of the mount doesn't have an integrated bubble level, so I use the Bubble Level app on my phone by setting it flat on top of the mount. Given the digital indicators this is probably more precise than a visual bubble level. I had it near perfect on my second run, but this didn't seem to help much. But I did notice that after a few hours of use the mount was suddenly much more tilted than it was initially... Could my setup be shifting around somehow ? This might be related to my second point... Or maybe I need to setup over more solid ground, like concrete instead of grass.
- A more stable tripod : I'm using the stock ZWO tripod. I realize it's not the most stable tripod around, but I figured that mattered more for AP and I got it as a lightweight, compact, grab and go tripod for ease of use and transport. But is it possible that it's so light and/or unstable that the mount is slightly shifting it as it slews around ?
Really hoping to get this to work better, because the mount is ticking every other box I need as the base of my travel setup : compact, simple interface, easy and reliable bluetooth connectivity, wonderful hand controller, great tracking etc. If I could just get this thing to point itself a bit better it'd be absolutely perfect. But as it stands my dob with a degree circle and an altimeter does a faster and much more reliable job of finding things. Honestly even if it were only reliable in the neighborhood of the last synced star that would be fine, as I could just sync to a nearby bright star then hop to my DSO. But even that has not been particularly reliable...
Very open to feedback on how I could improve this, or even just being told that unfortunately the AM5 just does a very poor job of this no matter what. If the latter then maybe I'll start working on how to put a degree circle on the AM5...
