After reading / watching quite a few reviews, I think I've narrowed down my choice for a sub $800 scope / flattener combo to either the SV550 or the Z61.
The scope will likely be used half the time for visual and half the time for photography. I like the 80mm triplet, but the FL53 glass in the 61mm double seems to be just as good on the spot diagrams.
If the build quality of the Z61 is leaps and bounds above the SV550, I'd definitely lean that direction since most of my viz stuff would be star clusters and brighter objects that could be seen with binoculars.
Are there be other (readily available) scopes that be included in this consideration?
Should a 6" SCT with reducer be in this group?
Thanks in advance for your suggestions!
