Strange behavor in Autostakkert! on long sequences of the lunar eclipse.
See the attached screen capture of Autostakkert! on the entire 7 minute segment and then reducing this to a 1 minute segment from the 7 minutes.
I had about 150 CR3 (had to convert to TIFF for Autostakkert!) images taken from 1:02 to 1:09 AM during the lunar eclipse on 2025-03-14.
The Autostakkertt! Analyse seemed to work OK with at least 50% of the frames above 50% quality.
But when I tried to stack over this long a duration, the image was blocky and chopped up. Note I was not tracking the moon but even tracking the change in size would probably throw off Autostakkert!.
Anyway, thought others might experience the same issue
The solution was to just stack subsets, 1 minute duration worked for me though I did not go through an measure image quality vs. stacking frame duration.
