Hi Everyone,
I'm having Dec alignment problems when I try to slew my mount to a target.
My setup is NINA/EQMOD/EQ6-R Pro/EdgeHD 11.
I use NINA's 3 point polar alignment for alignment (which seems to work), then try to slew to the target.
The problem is that it has stopped acquiring the target.
It slews, does a plate solve, says that the telescope is not in alignment and then just keeps repeating this process.
It looks like the reason it never properly aligns with the target is because the Dec error stops decreasing and just hovers around some relatively large value.
For example, from last nights attempt to target the Whale Galaxy
Time RA Error Dec Error
23:17:14 -00:00:10 -00 04' 39"
23:16:28 -00:00:09 -00 04' 40"
23:15:42 -00:00:10 -00 04' 40"
23:14:55 -00:00:09 -00 04' 41"
Further, when I gave up and homed the mount. The Dec dial didn't return to 0, it looks like it's off by a few degrees.
Does anyone have any idea what might be happening?
I'd appreciate any help...
