I really like long refractors, they have that 'Proper Telescope' look.
In the past I've had some Maks due to the limitations of my mounts.
I would really like an EQ-5 mount but am starting to think that I would need to break up the mount into at least two parts to move it around.
I think I've hit upon a size limit for my scopes, I'd like more power, more resolution but think 5" in a fairly compact tube is going to be my limit unless I can come up with some clever way of moving about a bigger mount.
As far as carrying capacity is concerned, you really don't need an EQ-5 class mount to hold a 5" Mak. I have mounted 5" Maks, 6" Maks, as well as 6" and 8" SCTs on my CG-4 converted to Alt-Az mode. Here is a 6" Mak on it:
All I have to do with the CG-4 is to remove the nut underneath the triagular leg brace/eyepiece tray and pull off the leg brace, then fold up the tripod legs. The CG-4 mount head stays attached, and I can lay the whole mount in one piece on the floor of my little car behind the front seats.
I had to make a modification to an Explore Scientific Twilight I that I has a few years ago to hold another 5" Mak:
The ES Twilight I comes with a long T-handle bar underneath the mount head. It is necessary to take that out and remove the mount head from the tripod in order to fold up the tripod legs for transport. That was something I did not want to have to do all the time, so I replaced that long T-handle with a length of M10x1.5 threaded rod. That way the mount head can stay attached to the top of the tripod, and made the Twilight I as easy to fold up as the CG-4.
What is not known is whether you prefer an EQ mount with counterweights and one-axis tracking using the R.A. control, or even automatic tracking and Go-To capability. If so, even an EQ-4 class mount with sufficient counterweights to balance a 9.5 lb. (4.3 kg) 5" Mak can be a little difficult to pick up and move around.
Edited by Oldfracguy, 21 March 2025 - 11:31 AM.
