RAW problem with SIRIL, DeepSkyStacker, PIPP and RegiaStax
Software DSLR
5 replies to this topic
#1 sehhaney
sehhaney
Posted 20 March 2025 - 10:50 AM
I'm not sure my other post made it, if it did please delete it and keep this one.
I have been using RAW .NEF files from a Nikon Z50 for all of the software with no problems. Now I have a Z8 and I get corrupted looking photos when loaded into the software. (see my album since I can't figure out how to attach a jpeg.) The Z8 has options for compression that the Z50 didn't have. Others suggested downloading the latest Nikon codec, not on their website now...: It didn't help. I have had to convert everything to tiffs which adds a lot more time to processing. I don't know if the software can't handle the newer compression or if changing the method will help. Has anyone experienced this problem? Solutions?
Steve
#2 scanner97
scanner97
  • Loc: New Hampshire
Posted 20 March 2025 - 11:01 AM
Are you using the lossless option with your .NEF file?  I think Siril has always been able to handle standard .NEF, which I assume that would be.
#3 sharkmelley
sharkmelley
  • Loc: UK
Posted 20 March 2025 - 11:09 AM
Yes, it's quite normal that newer compression methods are not supported because it takes a lot of work to add support.  If Adobe DNG Converter supports the format then you can try converting the files to raw DNG format and use them instead of the NEFs.
#4 nou
nou
Posted 20 March 2025 - 11:55 AM
Siril use LibRAW and Z8 is not on list of supported cameras https://www.libraw.o...pported-cameras
  • sharkmelley likes this
#5 scanner97
scanner97
Posted 20 March 2025 - 12:07 PM
The camera might not be listed because the compressed NEF files are not supported.  Or maybe Nikon changed their lossless NEF file too - which I would find strange, but you never know.  (This just seems to list cameras where there is "full support on all software".)
Edited by scanner97, 20 March 2025 - 12:09 PM.
#6 sharkmelley
sharkmelley
  • Loc: UK
Posted 20 March 2025 - 01:09 PM
RawDigger has only recently added support for Nikon HE/HE* compression (Feb 2025):
https://www.rawdigge...r-1-4-9-release
LibRaw typically lags behind RawDigger - its latest release was Sep 2024:
https://www.libraw.o...-0-21-3-release
My guess is that LibRaw support will arrive in due course
Also tagged with one or more of these keywords: Software, DSLR
