the 8in height is more manageable than the 16in.
i’d pay double if it was designed similarly to vixen’s half pier cutout for easier on/off mount head installation.
or losmandy style with slots for quick head bolts install.
sure beats fumbling with hex bolts in the dark trying to remove the original 16in extension.
difficult to wean off prc pricing, sure beats legal fees.
Losmandy uses what is called a bayonet mount. And very precise tolerances.
What I did was get the 12" extension with mine to give my camera et all clearance to swing. I built what I call my Portable Pier.
I recon the way I did it, I have 16" between the Tripod and the RA. Because there is a 4" MA on top of the tripod, and I mount the 12" extension to it with the hand screws.
I got the hand screws and put those at my break points, effectively making sections for moving everything.
The RAEXT was the last thing I added to make the RA and DEC dividable. Because having the RA and DEC as a one piece was just terribly heavy.
So, I have the HD Tripod, the 12" column and RA, the DEC, and finally everything from the clamp up.
4 chunks that all go together with hand screws at the connections.
I never got around to getting an extension for my AVX. I wanted one, but it only lasted me 3.5 years.
I got one of the bad ones.
When my AVX died for its third and last time, I had a 4 month wait imposed because it was right at Christmas. I was asked to wait until February. And I used it to get every detail in order for my replacement mount. I bought my GM811 on February 2nd of whatever year it was.
And I corrected everything about my AVX I wished was different, in my GM811G HD
Choices. Didn't have many back then, shucks, I didn't know I'd like this sport enough to stick with it.
But here I am, way deep in this black hole.
A big part of the cost is the engineering that goes into, and what the market will bare. It does cost a lot to make the commitment to invest in the machines and a Brick & Mortar place of business in the long shot your work will sell.
If you don't like the prices, you could do what Scott Losmandy did in the 1980's, start building your own.
But I wouldn't. Oh heck no.
A column extension can make your mount work so much better for you. But it is jumping deeper into the Black Hole.
