ASI174Mini - Visible via ASIair - Not in PC or MacOS
Equipment Imaging CMOS Software
2 replies to this topic
#1 jgs99v
jgs99v
  • Loc: SFBay Area
Posted 20 March 2025 - 02:30 PM
I reviewed many of the camera postings in the forum, seeking advice and possible other recommendations.
I've tried all of the suggestions: driver, Ascom drivers, Ascom Platform, cables, ports, computers and still device is not found.
This is standalone single camera connection directly to the USB-C or USB-A port of the computer.
Usually when you plug and unplug a device there is a system sound, and the "Device Manager" will reset with every insertion or extraction.
So seemingly its totally unrecognized.
Attempted to use ASICap, PHD2, SGP, Fire Capture and SharpCap - none of them will connect to the ASI174 mini, but I also have a ASI220 mini and ASI120 mini as my control units (make sure I did not break something with all the changes); and they all respond and operate as expected. Same computer, cables, ports and operating system.
I then tested the ASI174 with ASIair controlled by my Ipad. When I plug the ASI174 Mini using the cable off the ASI533MM hubs USB-A port - its recognized and able to run in camera mode or guide camera mode.
What is different from ASIair-->USB-A compared to PC-->USB-A/C?
What is unique about the ASI174 mini? I'm unable to update the firmware as the tool does not recognize the hardware.
OS = W11 Q4H2 updates (x2), MAC= Sierra (x2).
Suggestions welcomed and very appreciated.
  • Astro Jeep likes this
#2 maheitka
maheitka
  • Loc: Germany
Posted 20 March 2025 - 03:33 PM
Make sure your PC USB port ist type 2. I had the same problem with my 174mini when attaching it to USB3 ports.
CS
#3 jgs99v
jgs99v
  • Loc: SFBay Area
Posted 20 March 2025 - 06:57 PM
CS,
That is very interesting -
I performed some cable tests today.
If i used the cable that was plugged into the ASIair and it worked USBA to USBC on the PC laptop - but only two of four cables.
Whereas the ASI220 and ASI120 both were fine with any cable plugged into the either PC or MAC laptops.
I then ran some tests with my older Mac and newer Mac - USBC to USBC; all cables failed to recognize the 174, but the 120 nd 220 were all fine.
I submitted these questions to the ZWO Forum under camera's - looking a few minutes ago it was yet to be approved.
But I'm very interested in understanding if there is in fact a limitation.
Usually camera's you wish fast download times and 480MB does not cut it.  So let's wait and see what ZWO says.
Edited by jgs99v, 20 March 2025 - 07:04 PM.
Also tagged with one or more of these keywords: Equipment, Imaging, CMOS, Software
