I get the feeling the answer to this is going to be a heck no, but I figured I might as well ask.
I've noticed while looking over reviews for many of the medium duty mounts that their tripods all tend to have alignment pegs (ex. sky watcher eq5 & eq6-r, celestron avx)
Is there any chance this is a general standard and these mounts and tripods can be interchanged, or is it specific to each brand/model?
Tripods that hold GEMs (German Equatorial Mounts) all have those polar alignment pegs that function as stops that the two large East-West polar alignment screws butt up against underjneath the mount head. In the case of the Synta-made mounts (Sky-Watcher, Celestron, Orion and some older Vixen models) the tripods are interchangeable. For example, the SW EQ5 and HEQ5 tripods fit the Celestron Omni CG-4 mount perfectly. The old Celestron CG-5 tripod will actually carry a SW EQ5, HEQ5, CG-4, Orion SkyView Pro and Vixen Great Polaris mount with no trouble. Here is an Orion SkyView Pro GEM on top of a Sky-Watcher 20cm Pier Extension column on tpo of a Celstron CG-5 tripod:
Some tripods sold with Alt-Az mounts do not have that GEM alignment pin, but other than that they are exactly the same basic tripod supplied with GEM mount heads. As a case in point, the "Heavy Duty" tripod sold with the Sky-Watcher AZ5 Alt-Az mount:
is the very same tripod supplied with the Celestron Omni CG-4 mount:
except it has a flat top with no alignment pin, and the threaded rod that attaches the mount head to the tripod has 3/8"-16 threads instead of the M10x1.5 threads used on the Omni CG-4 and old CG-5 GEM tripods.
Note that even though the old Celestron CG-5 and current Advanced VX (AVX) mounts use the same tripod, the GEM alignment pin on the AVX is way out at the edge of the flat upper surfacce of the tripod top, rather than only 1.5 inches from the center bolt as shown (yellow arrow) on a CG-5 tripod below:
So, an AVX mount will not fit on an old CG-5 tripod.
I have actually hacksawed off the GEM alignment pin on an Omni CG-4 GEM tripod after converting the CG-4 mount to Alt-Az comfiguration. That way I could attach the CG-4 mount head at a different rotational angle as viewed from the top in order to get the scope in a better position relative to the extended tripod legs when viewing at high upward angles.
Edited by Oldfracguy, 24 March 2025 - 05:34 PM.
