Mars redux...
14 replies to this topic
#1 Kokatha man
Kokatha man
Posted 22 March 2025 - 03:00 AM
I must confess that I think it's usually slightly "bad form" to repost an image after just posting it in another thread recently, usually content to just post newer processings (if I have done so) down at the bottom of the thread where I know a minority of regulars will still look at them..! lol.gif
However, as I went to the bother of re-processing each of the 5 captures we took on this particular night I thought it worthwhile to create another thread, if only because it'll likely be the last thread for quite some time from us: the only real difference is that I went down to 55% quality cut-off for the stacks which meant instead of the original 19,400 frames in toto in WJ I wound up with about 67,000 frames in the integrated stack.
I did upscale the 1.5x drizzles to 225% before putting them through AstraImage and unlike the first processings I did not "weight" the stacks in WJ when integrating them.
Capture details are naturally the same grin.gif where seeing was what I term "pedestrian" at 29° elevation with Mars at 9.3 arcseconds.
I feel slightly better with this outcome if only marginally but in hindsight quite satisfied because of the size and elevation of the planet, despite any misgivings about the seeing...and anything else I tend to grumble about!shocked.gif lol.gif
Slightly better (subtle) albedo variation with (slightly) better feature definition imho.
Here's the new processing with an added 200% scale image and for completeness a second image showing the new processing on the left and old one on the right for better comparison... wink.gif
Also the short snippets of the feed of one capture from the start (ie, not quality-ordered) plus the feed after quality-ordering. I had to increase the canvass size and brightened the frames slightly for the quality feed. You might be able to just discern Tritonis S. and Nodus Alcyonus flickering in and out in the feed - these were used to determine optimum focus.
  • davidmcgo, lukasik, John Boudreau and 20 others like this
#2 Foc
Foc
  • Loc: South Canberra
Posted 22 March 2025 - 04:01 AM
Good reprise!
#3 Spacedude4040
Spacedude4040
  • Loc: Lat 42 degrees, Canada living under a 30-40 m/s Jet Stream
Posted 22 March 2025 - 07:10 AM
Thanks for sharing the info.
#4 JMP
JMP
Posted 22 March 2025 - 12:27 PM
Nicely done, Darryl! It always amazes me what you can pull out of "pedestrian" seeing!
#5 KMH
KMH
Posted 22 March 2025 - 02:08 PM
That's a terrific result!  I think the revised processing does have noticeably better clarity and detail.
Kevin
#6 Space Cowboy
Space Cowboy
  • Loc: Cheshire, UK
Posted 22 March 2025 - 02:34 PM
Super detail Darryl considering Mars is now so small. Maybe its my monitor but the ice cap does look very bright?
#7 Mike Spooner
Mike Spooner
    Vendor (mirrors)
Posted 22 March 2025 - 06:35 PM
More detail and less noise so definitely deserves its own thread.waytogo.gif waytogo.gif waytogo.gif
#8 Mitchell Duke
Mitchell Duke
  • Loc: Classified
Posted 22 March 2025 - 09:53 PM
Very nice effort!
#9 Kokatha man
Kokatha man
Posted 22 March 2025 - 10:19 PM
You actually picked up what I should have noticed & attended to in the first place - and something I have been guilty of at other times as well! blush.gif
Folks know that I deal with Mars "rind" with non-destructive dodge & burn...whereby I first create two separate images as single stacks then as WJ integrations which I label "SP" & "HP" - soft and hard processed.
Then I first attend to the rind in the "SP" image which then displays virtually no rind and shows the polar caps at an acceptable brightness - any sharpening can easily "blow out" these ice caps but the mild sharpening in these "SP's" are fine imo - although one can drop their brightness by some dodging of them, but this really isn't part of my schedule.
Then I simply use a "Layer Mask" of the "SP" over the "HP" image to ameliorate almost all of the rind* and this is where I sometimes forget to apply the mask to the polar cap - which is what I did here! crazy.gif
*As I said earlier, WJ seems to ameliorate the rind by itself when the capture timespan is over longer durations (like this was) and the lower LD values I use. (0.77) Any rind left after the layer mask from the "SP" after merging the 2 layers can be fixed with a bit more "n-dd&b."
I've sorted it out a bit better now in the image below although I should have gone back to the start with the images straight out of WJ...but it will have to do now - but "thank you" regardless Stuart because I can overlook that step sometimes and it is frustrating to spend time and overlook something simple! waytogo.gif
  • KpS, Space Cowboy, Mike Spooner and 4 others like this
#10 Kokatha man
Kokatha man
Posted 22 March 2025 - 10:22 PM
ps: another "mea culpa" in that the quality-ordered feed snippet has a frame cropped, or at least looks as though it does...the ROI that I used was tiny in AS! and I suspect this was the reason when taking screenshots and increasing the canvass size to show a colour feed... confused1.gif
#11 Tulloch
Tulloch
  • Loc: Melbourne, Australia
Posted 23 March 2025 - 06:21 PM
Great detail there Darryl, and rind has been well treated. I'm struggling with mine at the moment, no amount dodging, burning, layering or healing will fix it :(.
#12 Space Cowboy
Space Cowboy
  • Loc: Cheshire, UK
Posted 27 March 2025 - 03:31 AM
They look very nice Darryl. I always check the icecap first when I view a Martian image. It's like the yolk on a fried egg. Always like to see the yolk nicely basted and not over done. 👍
#13 Markp910
Markp910
  • Loc: MI
Posted 27 March 2025 - 12:57 PM
attachicon.gif 2025-03-17-1106_8-FeedStart.gif     attachicon.gif 2025-03-17-1106_8-FeedQuality.gif
These are great
#14 azure1961p
azure1961p
Posted 27 March 2025 - 08:36 PM
LOL, after viewing with my 4" frac, Kokomo, this is like NASA Imagery lol.  Excellent again.
Pete
#15 Kokatha man
Kokatha man
Posted 28 March 2025 - 03:23 AM
No runny yolks for you Stuart..?!? grin.gif  Thanks also Mark and Pete - and to all the extra "Likes." smile.gif
