I need help with my flats.
I have been capturing and using flats in sharpcap for a long time now. It worked well. But recently I have run into this problem.
I captured flats using both sky illumination as well as my LED panel. I confirm that the white curve in the histogram is in the middle, and sharpcap also says "OK" for histogram. However when I use flats, I get this weird reverse-corrected image. See the first attachment. I'm also attaching the camera settings file that sharpcap saved during this capture.
Even weirder: when I disabled darks, the image became much better! The image was almost uniformly lit, as if the flats did correctly correct the exposure. Now I'm really lost! My camera is a QHY 533C (cooled camera, so I have been using its darks for several months now).
The only change I can think of is that I'm using a night owl 0.4x reducer with my C8. This does produce more vignetting than my 0.63x reducer, which is precisely why I need my flats! I do not remember for sure if this problem has started since I started using the new reducer, but I do not believe so.
Any insights?
Edited by amitshesh, 22 March 2025 - 11:05 AM.
