I was wondering if anyone has used an AZT6 L Bracket from Teleskop Service? If so, what are your thoughts on this bracket?
I would really like to use altaz mounts with GOTO & tracking with my different binoculars (as small as my 10x50s and as large as my Oberwerk BT127 mm). The issue that I am running into is that many of these mounts have their saddle in a side mounted position.
The only altaz mounts with GOTO & tracking with a top mounted saddle that I am aware of are:
Panther TTS-160 (now discontinued)
iOptron AZ Mount Pro w/ Binocular Adapter
Emcan EM31 Pro in Alt/Az Top-mounted mode
If you know of any others, please let me know.
I am interested in the AZT6 L bracket because I think that would open up a lot more variety in terms of mount options, especially those available on the used market.
I could also better match the weight capacity of the mount to the mass of the binos (i.e. use a smaller mount with smaller binos, use a larger mount with heavier binos). Stated maximum load for the L-bracket: "Instruments up to approx. 15 kg weight"
I would appreciate any and all thoughts on this particular L-bracket or using L-brackets with binos in general.
Edited by Random2310, 22 March 2025 - 05:33 PM.
