Hey Jacob.
For the most part, the biggest obstacle that you will have to high power viewing, with your present equipment, will likely be related to local seeing conditions. Seeing refers to the effect that atmospheric turbulence has on images that you view at the eyepiece. A good example would be in the summer when you look at an object across hot pavement and it appears to get distorted/ wavy (refracted). This atmospheric refraction, which has other causes that cannot be controlled for, will also affect astronomical targets, especially planets and lunar.
To minimize this, you should try to view later in the evening when a lot of the daytime heat has dissipated. You should also set up your telescope on grass/dirt/natural ground and try not to view targets over buildings or large parking lots. It is also best to view targets when they are highest in the sky and closest to the meridian (imaginary line that divides the eastern and western sky). By viewing when target is highest, this will minimize an effect called atmospheric dispersion and ensure that you are viewing through less atmosphere which may minimize atmospheric turbulence.
Lastly, with regards local seeing conditions, and since you live in an area prone to a significant day/night temperature differential, you should consider wrapping your telescope in an insulating material such as Reflectix. This will ensure that your telescope maintains thermal equilibrium in order to minimize internal tube currents (related to heat loss as telescope cools down. These currents will significantly degrade your views.
Another thing that you should do to extract every bit of performance out of your telescope is to make sure that it is properly collimated.
Other than that, you will need to experiment with different equipment combinations to see what appears most visually appealing at the eyepiece.
Karl
For some reason I cannot add a hyperlink to the Reflectix term I used above so here it is:
https://www.cloudyni...with-reflectix/
Edited by kgb, 23 March 2025 - 10:31 AM.
