Test TEC 140 ED (DPAC)
34 replies to this topic
#1 Psion
Psion
  • Loc: Czech Republic, Prague
Posted 23 March 2025 - 04:52 AM
After a long time I pulled the TEC 140ED (year 2011) out of storage to compare it with the Askar 203mm, and on that occasion I did a little DPAC test. It is obvious that Yuri can do it! The optics are amazing even if not completely free of chromatic aberration, but the focus was on eliminating other optical defects.
Edited by Psion, 23 March 2025 - 04:54 AM.
  • peleuba, BRCoz, mblack and 17 others like this
#2 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 23 March 2025 - 06:26 AM
It looks virtually perfect.  There's maybe a trace of sa in blue.  Is there a pic of a null test?
Edited by Darren Drake, 23 March 2025 - 06:28 AM.
#3 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 23 March 2025 - 06:57 AM
Maybe mine will be as good.
  • SandyHouTex likes this
#4 Erik Bakker
Erik Bakker
    Stargazer
  • Loc: Netherlands, Europe
Posted 23 March 2025 - 07:29 AM
#5 rachnoman
rachnoman
Posted 23 March 2025 - 07:41 AM
Would also like to see a null test. That will reveal what you've got.
#6 Psion
Psion
Posted 23 March 2025 - 07:53 AM
I've tried to make it, but I can't the area is almost completely uniform, without any zonal defects.
  • Jeff B and RAKing like this
#7 rachnoman
rachnoman
Posted 23 March 2025 - 09:25 AM
My null test uses a 1/10 wave silvered flat and a simple knife edge Foucault tester. No lens can escape detection of any defects with this basic direct test.
#8 Psion
Psion
Posted 23 March 2025 - 09:45 AM
Unfortunately, I don't have a Foucault tester; perhaps I should make one.
#9 saemark30
saemark30
Posted 23 March 2025 - 09:49 AM
Superb! Best DPAC I ever seen!
  • Psion likes this
#10 Scott in NC
Scott in NC
    Refractor Aficionado
  • Loc: NC
Posted 23 March 2025 - 09:52 AM
Very nice!  :waytogo:
  • Psion likes this
#11 scoale
scoale
  • Loc: Triad, NC
Posted 23 March 2025 - 10:00 AM
Interesting.  This tests far better in blue than the other two TEC 140 ED tests we have seen.
  • Scott in NC and Paul Morow like this
#12 rachnoman
rachnoman
Posted 23 March 2025 - 10:07 AM
A good guide for making one can be found in Sam Brown's book called "All about telescopes". The out-of-print book can be found on the used market.
  • Psion likes this
#13 PatientObserver
PatientObserver
  • Loc: Southern FL
Posted 23 March 2025 - 10:37 AM
That is a nice looking DPAC.
  • Psion and SandyHouTex like this
#14 PKDfan
PKDfan
  • Loc: Edmonton
Posted 23 March 2025 - 11:34 AM
I'd take that scope in half a heartbeat Psion !!
Just a Beautiful correction profile.
CSS
Lance
  • peleuba and Psion like this
#15 Scott in NC
Scott in NC
  • Loc: NC
Posted 23 March 2025 - 11:38 AM
I noticed that all of your images are presented here as monochromatic, so I’m curious as to how you derived the individual R, G, B colors (separate colored LEDs, like I did when I first started out, or separation of colors by software processing, like Jeff B. and I do now).
  • PKDfan likes this
#16 Psion
Psion
Posted 23 March 2025 - 01:42 PM
I separated the colors using PixInsight.
  • Scott in NC and PKDfan like this
#17 Maciek_Cz
Maciek_Cz
  • Loc: Poland, Lublin
Posted 23 March 2025 - 03:52 PM
I have a question about your photos and analysis by AOS. What ronchi screen did you use? In the AOS parameters you entered 10 lines/mm, but the photo does not show diffraction effects, which with such a grid in the double pass system should be significant. Wasn't it something like 4-5 lines/mm?
#18 Scott in NC
Scott in NC
  • Loc: NC
Posted 23 March 2025 - 04:47 PM
A few questions:
1. First, should “Ronchi Autocollimation” be checked rather than “Ronchi at Focus” on the AOS program?
2. Second, could you let us know whether these images were taken inside of focus or outside of focus? I’m assuming the former, given the parameters entered into AOS.
3. Third, would you mind also posting the “at focus” and “outside focus” images, if you took any?
4. And last of all, were the Ronchigrams cropped in any way? It doesn’t look like it to me, but just wanted to confirm.
#19 Maciek_Cz
Maciek_Cz
Posted 23 March 2025 - 04:56 PM
Scott, yes option "Ronchi Autocollimation should be checked when we consider DPAC configuration.
  • Scott in NC likes this
#20 Jeff B
Jeff B
    Anachronistic
Posted 23 March 2025 - 07:39 PM
A quick question Maciek, something I have been meaning to ask you.
There is also the "Moving source" check box.  I have been checking it because my screen and LED are in the same holder and move together while focusing and I assumed that is the purpose of that check box.  Is my assumption/reasoning correct.
BTW, I ran my TEC 140ED DPAC images in AOS, each side of focus, spherical only (which is reasonable for this objective) and the average spherical only Strehls are essentially .99 in green, ~.98 for red and ~.81 in blue.  I got good simulations with the same "Dist from ROC/Foc" parameter for all colors.
Jeff
Edited by Jeff B, 24 March 2025 - 11:31 AM.
#21 Psion
Psion
Posted 24 March 2025 - 06:17 AM
You're right, I'm sorry, I entered the wrong value. I normally use Ronchi 10 lines/mm, but in this case I used a different instrument with 5 lines/mm.
  • Scott in NC and Maciek_Cz like this
#22 Psion
Psion
Posted 24 March 2025 - 06:24 AM
A few questions:
Let me see, somewhere I have photos taken outside of focus. I only evaluated the ones inside of the focus.
The Ronchi image is not cropped in any way and is as captured by the Olympus camera, only the black edges are cropped.
#23 Maciek_Cz
Maciek_Cz
Posted 24 March 2025 - 01:59 PM
Thank you.
Now you should redo AOS analysis:-)
#24 Maciek_Cz
Maciek_Cz
Posted 24 March 2025 - 02:03 PM
Hi Jeff,
Your reasoning is correct. In this setup where led moves with ronchi screen we should check "Moving source" checkbox:-)
  • Jeff B likes this
#25 Psion
Psion
Posted 24 March 2025 - 03:52 PM
Thank you.
I tried to do the analysis again, and it comes out similarly
