Orion Dobsonian XXg Goto tracking
Orion Mount
10 replies to this topic
#1 stewartcross
stewartcross
Posted 23 March 2025 - 05:06 AM
The azimuth tracking on my Orion SkyQuest XX12g Goto (purchased 2019) has stopped working. The drive motors are fine but the azimuth reading no longer changes as the base rotates. Consequently the whole setup is useless as it won't slew or track
Attached are images of the sensor which no longer works. The identical altitude sensor is fine.
Does anyone have any idea whether I would be able to find a replacement?
#2 ngc7319_20
ngc7319_20
  • Loc: MD
Posted 23 March 2025 - 07:07 AM
Does the elevation encoder look identical?  Have you tried just swapping the elevation and azimuth encoders, and see whether the problems moves with the azimuth encoder?
This just looks like a LED / photodiode pair.  You could probably replace the components on the board.  I'd also try wiggling the connector -- might just be a connector or wire issue.
  • stewartcross likes this
#3 mayhem13
mayhem13
  • Loc: New Jersey
Posted 23 March 2025 - 07:12 AM
I would contact Sky-Watcher support…..I think their  goto dob motors and control are the same.
#4 stewartcross
stewartcross
Posted 23 March 2025 - 09:52 AM
Thanks, yes I swapped the two encoders and the problem moved, so it's definitely this board. Sadly, no amount of wiggling fixes it. I will contact Sky-Watcher support
#5 Mike Q
Mike Q
  • Loc: Monnett Ohio
Posted 25 March 2025 - 07:27 PM
Hit up encoder product company.   Send them the picture that you posted and see what they can do for you
#6 stewartcross
stewartcross
Posted 01 April 2025 - 10:27 AM
I don't know who the encoder product company is, only the overall manufacturer which was Orion. Do you or anyone else know?
#7 ngc7319_20
ngc7319_20
  • Loc: MD
Posted 02 April 2025 - 08:40 AM
Since you have one working encoder (the other axis) and one dead encoder, you have a lot to work with.  I'd focus on a board level repair.  You've got only 3 parts on the board.    Get an ohm meter and go around the board comparing resistances between the good and dead board.  You need to test both polarities (reverse the test leads).  That should let you figure out which part is bad.  Get a photo of the dead part -- put it through a Google lens search.  Note any numbers on it.  Use terms like LED, photodiode, phototransistor.  Companies like Mouser and Newark sell almost every electronic part ever made.
Also consider whether there is just a mechanical fault.  There must be an encoder wheel, shaft, etc. this board reads.  Something with black bits, or reflective bits.  Make sure that part seems OK.
Edited by ngc7319_20, 02 April 2025 - 08:42 AM.
#8 stewartcross
stewartcross
Posted 10 April 2025 - 07:21 AM
Yes thanks ngc7319_20, that all makes sense. It's definitely the encoder board because I've swapped the good and bad ones and the fault swaps with them.
No numbers on anything unfortunately but I'm sure I can work out which component is the faulty one and find an appropriate replacement.
#9 rmollise
  • Loc: US
Posted 10 April 2025 - 09:58 AM
Orion wasn't the manufacturer. This scope was made by Synta, who sells under the SkyWatcher brand (and others). Contact SkyWatcher USA.
#10 Mike Q
Mike Q
  • Loc: Monnett Ohio
Posted 10 April 2025 - 03:46 PM
https://www.encoder.com/
They might be able to help sort you out
#11 stewartcross
stewartcross
Posted 14 April 2025 - 04:01 PM
Thanks everyone
Also tagged with one or more of these keywords: Orion, Mount
