Hi have a Dobson 12.5" f/4.5
Would it make a worthy difference between owing a Tele vue 10mm ethos vs 10mm delos for visual observation?
Assume money is not a constraint, but my question is on the "value for money". Will I be able to see a value of difference by opting to go for ethos?
Pls advise.
The 10mm Delos is one of the sharpest eyepieces I've looked through. I would say it's a very slight hair sharper than the 10 Ethos but requires a good objective to pick out the differences.
For critical planetary observing, I would pick the Delos over the Ethos.
For general purpose deep sky observing, I would pick the Ethos over the Delos just for the expansive field of view, but only if you have or plan to get a Paracorr. Coma at F/4.5 in a 100 degree eyepiece is distractingly annoying, and it makes no sense to spend several hundred dollars on the field correction you get from Tele Vue only to use it in an uncorrected telescope.
The 10 Ethos is the most comfortable of the line for me - was my favorite when I owned it. I only sold it because I replaced it with a Nikon NAV-HW converted to 10mm mode. Not everyone likes 100 degree eyepieces, but the 10 Ethos is one of the most comfortable 100 degree eyepieces you can get.
Optical differences between the two are splitting hairs. Ergonomic differences between the two are significant. It's hard to say which one would be best for you - you sort of just have to try them for a while and see which you really prefer.
