Maybe this topic has been discussed here before , if not , i found an info that resolves the problem of having to constantly re-ajust the thumb screws on a finder scope.
On my scopes, when i take them out , i have to re-ajust the finder scope with the 2 thumb screws , because the ''spring thumb knob'' always allow the finder to
move when i remove the protective caps on the finder. It was annoying to re-do everything in the dark after adjusting it in day light.
I removed the spring knob and replaced it with a M8X1.25 screw , using a tap of the same size. I just finished adjusting them a few minutes ago and they don't
move anymore!
When i bought the little svbony raci finder on amazon , i went in the reviews below and that is where i found that info.
I used phillips screws , but i plan to go to a machine shop and buy a couple of black screw with grooves around the knob , like the existing adjust screws on the finder
so they won't slip when i tightened them.
Edited by northernmike, 23 March 2025 - 10:28 PM.
