Edited by kingsbishop, 23 March 2025 - 11:09 PM.
In perfect seeing how bright is the first diffraction ring compared to the spurious disk
#1
Posted 23 March 2025 - 11:08 PM
#2
Posted 23 March 2025 - 11:17 PM
It depends on the telescope. The size of central obstruction (if any) and other optical aberations will change how bright the first ring is. You would also need pretty good seeing for a 8" scope to show truely steady diffraction rings.
But once this is all met, I have seen in small refractor, in focus, 3-4 rings during star testing.. Same as you would see with a much dimmer star, like Polaris. As the number of rings you can still see is about the contast, i.e. scatter in the sky, telescope and ultimately in your eyes, too. So with Sirius you won't see any more than with Polaris.
Edited by triplemon, 24 March 2025 - 12:28 AM.
#3
Posted 24 March 2025 - 12:01 AM
With a scope with a large central obstruction like an Schmidt-Cassegrain, the first ring can appear as bright as the disk, almost. in addition, any bright star will show more than one ring, even in a refractor.
#4
Posted 24 March 2025 - 05:47 AM
huh how does that work the second ring has a surface brightness way dimmer than the limiting magnitude with an 8 inch with perfect opticsIt depends on the telescope. The size of central obstruction (if any) and other optical aberations will change how bright the first ring is. You would also need pretty good seeing for a 8" scope to show truely steady diffraction rings.
#5
Posted 25 March 2025 - 12:04 AM
With perfect optics you'll be hard pressed to even see the 3rd.
Or add a large CO and both the 3rd and 4th will get definitely be there. A occulting bar to suppress the center also greatly helps with shenanigans like this.
