Thats really saying something coming from you as I seem to recall you are a fairly serious and active observer. What f ratios are you using these eyepieces with BTW?
f/8 to f/15, chiefly.
I've used the 26, 16 and 10 on my 125/1000mm Vixen catadioptric Newtonian with excellent results, and the 16 and 10 on my 6" f/8 Dobsonian with similar results. The edges aren't crisp, but they're not total disasters, either, and still eminently useful for target location and general context. The inner 50% of the field is essentially ortho-like sharpness and contrast, with the added benefit of the 85° field for context.
In my 63/840mm (f/13.3) Zeiss Telemator, the entire field in the 32mm appears sharp, when you look at objects close to the center, because the lower resolution of the periphery of your vision doesn't allow you to detect the mild unsharpness of the stars. Even with direct vision, stars near the edge are only mildly bloated. Rich star fields and open clusters, such as the Double Cluster, or the area around M35, look amazing.
It must be remembered, that these eyepieces are designed with slow f-ratios in mind, and to deliver the absolute maximum sharpness and contrast in such telescopes. They're not for fast systems under f/8. Even so, I've tested the 16mm in my 72mm f/6, with surprisingly decent results. The inner 50% of the field was still extremely sharp, while the edges were noticeably bloated, but less than I had anticipated.
What I particularly like about them, is their small form factor, and low weight. This is very important for small telescopes.
Clear skies!
Thomas, Denmark
