What can you expect from a 200mm dob (8inch)
83 replies to this topic
#51 Tony Flanders
Tony Flanders
  • Loc: New Lebanon, NY and Cambridge, MA, USA
Posted 26 March 2025 - 02:40 PM
I'd hate to think how my back would feel after 3 1/2 hours at the eyepiece of a Dobsonian. With a refractor observing is so comfortable and effortless.
And I feel exactly the opposite. I find Dobs supremely comfortable due to the limited range of head height as the scope slews from horizon to zenith, and refractors a major hassle due to the huge range of head height even of small ones. Long refractors are just awful; they require immensely tall tripods, and even then you may end up with your chin on the ground when viewing the zenith.
With my 7-inch Dob I can view very nearly the entire sky while sitting comfortably in a standard chair. My 130-mm f/5 tabletop is even better in that regard.
With my 12.5-inch f/5 the eyepiece is usually at ideal position for standing, though I do find an adjustable-height chair handy for viewing less than 45 degrees above the horizon.
  • Dave Mitsky, Don W, Brent Campbell and 5 others like this
#52 3C286
3C286
  • Loc: Netherlands
Posted 26 March 2025 - 05:02 PM
I've watched Ed Ting rate the 8inch dob as his "if i could only have 1 scope", even more than the 10 inch due to size,awkwardness etc.
I have never looked through one before.
Biggest Ive used is a 5inch dob and I found my 80mm ed apo more contrasty and sharper on planets and moon.
Does anyone have any stories or comparisons between an 8 inch dob and smaller apos. Was it a wow moment viewing the moon, planets or dso after using a smaller scope (which scope)
I had no idea or may have forgot a 8inch dob is only £370. Going to keep my 80mm apo and get a dob as opposed to 120mm skywatcher ed ( would have cost over £2000 incl a mount).
Hi Arkade
I started off with a 102-mm achromat and within 3 months, got an 8" Dob, then an 80-mm achromat (ST80) three months later. You probably have a lot more experience than I did at the time but this is what I wrote in my logbook for my first light with my 8" Dob:
"Dobsonian 8": Impressions
It's really hard work. For a start it's heavy and a bit of a hassle to set up. It's really awkward leaning over to use the straight finder: You need to get into all kinds of positions. M38 was clearly made of dots. Orion Nebula (M42): You felt as though you could see the nebula clouds"
It really was a big step up from a 102-mm refractor. As my notes above show, seeing M42 so much brighter and with so much detail was a revelation to me. As a beginner, it was much easier for me to detect faint fuzzies in an 8" Dob because they were brighter. When I got an 80-mm refractor three months later, I was a bit disappointed because everything was darker and less vivid. At the time, I could see much more with the 102-mm refractor than the 80mm.
If lunar observing is your thing, I like using the 8" Dob for the moon because I tend to get limited by floaters and the bigger aperture allows me to use higher magnifications before I hit my floaters limit. But that's just me.
My recommendation is to just go for it and get an 8-10" Dob. Keep it for a whole year and see what you think. If you it's not for you, they're relatively easy to sell on.
Hope that helps
Tak
  • Arkade likes this
#53 Sebastian_Sajaroff
Sebastian_Sajaroff
Posted 27 March 2025 - 06:16 AM
An 8" Dob is a powerful first choice for beginners.
Easy to mount, point and use, no shaking, views are quite impressive (under reasonable expectations).
Negative points : the base’s weight and thermals. Once you take it outside, give it 45-60 minutes to cooldown, that simple delay makes a brutal difference on planets, Moon and doubles.
Tip : don’t be OC on collimation and level. I don’t get why people get so obsessed with both.
Unless you take your Dob on a road trip every night, it shouldn’t need a daily collimation.
IMHO, turbulence above, inside or around your telescope has a deeper impact than a slightly off collimation.
My backyard has a 3.5° slope, never affected my Dob on any noticeable way.
  • dnrmilspec and Arkade like this
#54 Jon Isaacs
Posted 27 March 2025 - 07:10 AM
My two cents (again):
What can you expect to see with a decent 200mm Dob that is properly collimated and cooled?
I have two excellent 4 inch refractors as well as some quality 70mm, 80mm, 90mm refractors. I do like refractors. I own and observe with some pretty large aperture Dobs but  I have owned several 8 inch Dobs and have had my 10 inch F/5 for over 20 years. I still use the 10 inch quite often.. It's big enough to do some real damage but not so large as to be an issue setting it up.
I do recommend the 10 inch over the 8 inch if you are in reasonable physical condition and of reasonable strength.  My gut feeling is that Ed Ting is on the smaller side physically.  I will be 77 years of age here in a week or so, I am stronger than most senior citizens but the 10 inch Dob is relatively easy to carry out in two pieces. Here's a couple of photos with my 10 inch:
That said:
You will see a lot more than you will see with a high quality 4 inch refractor or in either of your current scopes.  You will have to pay more attention to the scope, collimation and cool down are critical.
Through the eyepiece, the resolution is seriously greater, it collects a whole lot more light. The planets will be more detailed and more colorful.  You will be able to split closer double stars.  The scope will go deeper, you will see fainter galaxies, galaxies will show more detail, better resolve globular clusters, open clusters will show more stars and the stars will be brighter.  Planetary nebulae will show more features, more detail.
An 80mm - 100mm refractor and an 8 inch or 10 inch Dob or SCT really complement each other, they are great companions.  One goes deep and provides detail, one is handy, ready to go in a moment and provides very good views for it's aperture.
In your current situation, you have a couple of smaller scopes, you are looking at acquiring something larger.  It think it's a wise step.  In this hobby you will find many amateur astronomers who observe with only one kind of scope and they like to recommend the type of scopes they like.  Personally, I like refractors up to 4 or 5 inches as well as larger reflectors.  I am not an SCT guy but SCTs are more compact than Dobs and require less fiddling so they are a viable alternative. If you view telescopes as tools to observe with, I do, then having a range of apertures allows you to view the widest range of objects and under the widest range of conditions.
Edited by Jon Isaacs, 27 March 2025 - 07:36 PM.
  • Dave Mitsky, m2k, Russell Swan and 5 others like this
#55 Jon Isaacs
Posted 27 March 2025 - 07:11 AM
The refractor will also give you breathtaking rich field views of star fields like no other scope can. Only two nights ago while observing with my 100mm F8 refractor and nothing but a 23mm Pentax XW eyepiece, I spent three and a half hours simply drifting through the constellations, stopping for a while at every cluster, asterism,  colourful double star and nebula that dared to enter my field of view. I've had bigger reflectors and refractors, but the 4" refractor is my most prized possession and I'd never part with it.
I'd hate to think how my back would feel after 3 1/2 hours at the eyepiece of a Dobsonian. With a refractor observing is so comfortable and effortless. And I can carry the whole scope along with tripod and altazimuth mount with just one hand, not that I would! When on a driven equatorial, I can really relax, as the scope just follows whatever object I'm studying. After 45 years of observing, a 4" refractor is my most used scope, and because of this, it is the scope that has shown me the most.
A few random thoughts and experiences:
- Rich field views are somewhat different than wide field views.  Rich field means a lot of stars in the field and that requires a fast scope with a wide field eyepiece that provides as large exit pupil. The 23 mm Pentax XW has a calculated field stop of 34.1mm, it is probably smaller than that.  In a 100mm F/8 refractor, that provides a 2.44 degree field of view at 35x with a 2.9 mm exit pupil.
An 8 inch F/6 Dob is capable of a 2.2 degree AFoV with eyepieces like the 41mm Panoptic or the generic 38mm 70 degree.  That will provide about 40x with a 6.7 mm exit pupil.  The FOV is slightly narrower but the image is far brighter, you see more stars, you see fainter DSOs..
I love the big wide, rich field views my fast refractors can provide.. The 4 inch F/5.4 does 4.5 degrees at 17x with a 5.8mm exit pupil.. But also impressive is the 1.6 degree field of view at 48x with a 6.6 mm exit pupil of my 12.5 inch Dob. Cruising the summer Milky Way under dark skies, it's a treat one won't forget.
- It seems you have not spent a night with a adjustable observing chair and an 8 inch or 10 inch Dob.  As Tony said, it is more comfortable and requires fewer adjustments than a refractor.  Even a relatively short refractor requires a lot adjustment range because the the eyepiece in the diagonal are always pointing in the wrong direction, vertical when viewing near the horizon so the observe has to be above and looking down.  Viewing near the zenith, the eyepiece is horizontal and down close to the ground.. Down on my knees..
With the Dob, the eyepiece is correctly oriented, it's horizontal with viewing near the Zenith, at 45 degrees near the horizon so you can look down from above.
  • Russell Swan, dnrmilspec and Arkade like this
#56 northernmike
northernmike
  • Loc: Laurentian mountains, Quebec, Canada
Posted 27 March 2025 - 08:42 AM
I too saw the Ed Ting video and went for an 8"dob and it was my best move.I bought my first scope in sept. 2023 , so I'm a 63 yo newbie. It was a 5" reflector on an eq mount , big mistake for a newbie. The scope was perfect with good optics and EPs , but the mount was shacky and crappy , like most scopes in that price range.
I saw jupiter and Saturn for the first time with that scope , I was impressed to see the gas band of Jupiter and the rings of Saturn with that small 5".
When I bought my 8"dob and looked at Jupiter with it , I knew I made a good move , I was more impressed and it wasn't even well collimated , I had no experience in that domaine. I was using the EPs that came with my 5" Orion , 25 and 10 mm sirrius plossls , I compared those with the "super plossls" 😅 that came with my 8" SW and it was at that moment that I realized the difference between EPs. My first upgrade was the svbony goldline serie , 20,15,9 and 6 mm. I must say that it was a pretty good upgrade , even if my 25 mm sirrius was used the most.
I liked this scope so much that I bought another one , a 6" portable virtuoso SW for my fishing trips in bortle 1 spots. Since then , I sold my 5" space probe reflector and looking to buy a 4" refractor for astrophotography.
But for viewing only , my 8" dob will always be my first choice , I saw my first dso with it, close up of the moon , double stars etc.... I upgraded my EPs again , this time with ES , a 24 mm 68° , 14 mm ES 82° , 10 mm 82° SR , 5.5 mm 82° Meade, a 2X ES focal extender and a 32 mm 2" Q70. With this kit , I took my viewing experience to another level.
I also upgraded my 8"dob with a dual speed focuser, Telrad , raci finder ,new compression ring adapter , a fan , counter weight , carry straps and I flocked the tube.
With those upgrade , it's even better.
It's in my home to stay , I will never get rid of it.👍
  • Arkade likes this
#57 daveb2022
daveb2022
  • Loc: San Joaquin Valley
Posted 27 March 2025 - 12:24 PM
I tend to use various scope designs for different purposes. Most revolves around comfort and a back injury. It's not that the dob kills my back to use, but I'm one who feels much more comfortable at a scope on a tripod. Yet, I agree with others that observing around zenith can be an issue using a standard tripod and is something I usually am willing to avoid. The Dob fits a role for me as a zenith instrument. It runs well against my C925, is often challenging my 4" APO on planets, and can do better on specific DSO's that require a reasonable aperture (from my location). But in a confined spot like where I observe from, my XT8 is hampered by being so low to the ground. It doesn't get much use, but is worth the effort to set up if there is a target worthy of viewing directly overhead. The XT8 is light enough at about 25 pounds, it doesn't bother my back. It has enough aperture to provide some performance in my light polluted skies. Setup couldn't be quicker and it has a very stable platform. Can't argue with its price. I'm in such highly polluted skies that I use NV 90% of the time. My dob is not suited for NV IMO. That is not against all dobs, just my XT8 has a horrible focuser. But it still provides value when used visually. At times it is just the best tool.
  • arg0s likes this
#58 Whiteduckwagglinginspace
Posted 28 March 2025 - 10:37 PM
About choosing between 8 an 10 inch dobsonian:
It's true that you don't pay much more for a 10 inch. And you see a bit more, but not a lot more. (objects are a bit brighter / bit more detail, but not that much)
But there are also disadvantages:
- The mirror of an 8 inch cools faster than a 10 inch (thicker) mirror.
- Adapts more quickly to temperature changes.
- Probably you need a coma-corrector for the 10 inch.
- Probably you need more expensive eye-pieces for the 10 inch.
- Probably you need to collimate more often with the 10 inch.
- Collimation needs to be more precisely with the 10 inch.
- When living in an area with lots of turbulance, you can better opt for the 8 inch, because it will 'catch' less turbulance. (opinions can differ on this)
- 10 inch dob is more sensitive for wind than an 8 inch dob.
- The 8 inch is sharper to the edges, where the 10 inch can be slightly less sharp to the edges
- The 10 inch is not that much heavier, but because of bulkiness, it feels heavier.
  • TheChosen and Researcher like this
#59 dnrmilspec
dnrmilspec
  • Loc: Southern Arizona
Posted 28 March 2025 - 11:21 PM
I am not trying to be contrary, but where did you hear these things?
There are soooo many other factors that weigh on these generalities that the ones above (other than ease of moving them) are of little importance.    And even that weight is not huge.  For example, the Skywatcher 8" OTA is only 8 pounds lighter than the 10" one.
Consider the ease of use for example.  I had the occasion to use a 10" F6 one time.  Though it was a tad harder to move, its eyepiece height was far more convenient for me.  And it was a lovely planetary scope not to put to fine a point on it.  If that one had followed me home, I would have kept it.  It should be remembered also that a 10" gathers a significantly greater amount of light.  I can easily see the difference between my 8" SCT and my 9.25SCT.  My 10" SN at F4 is a stunning sky sweeper.  So deep.
Many of the disadvantages you forward are virtually insignificant or not based on the science or the experience of many users, and we probably should not discourage new folks from considering the advantages that greater aperture offers.  There are great  reasons to choose either one.
  • Don W, BillShort and Arkade like this
#60 A Star Geezer
A Star Geezer
  • Loc: Ohio
Posted 29 March 2025 - 11:09 AM
Don't know if I should e commenting. Bought my first scope in November, after researching for a while I settled on an 8inch dob but bought a 10inch due to it being on sale. Jon Isaac and I are the same age the weight of the dob isn't over whelming , You know your holding something but it's not too much. The bulkiness is more of a problem than weight. The only problem I have is the bulkiness of the rocker carrying  through the door way.
  • Jon Isaacs, areyoukiddingme, Neanderthal and 2 others like this
#61 Whiteduckwagglinginspace
Posted 29 March 2025 - 02:19 PM
Strange question...Before I bought my 8 inch dob, I gathered a lot of information between the 8 and 10 inch. Most of this information, comes from people with experience with 8 and 10 inchers. Also on this forum.
Please tell me which of the 10 points is/are not right and why.
There are soooo many other factors that weigh on these generalities that the ones above (other than ease of moving them) are of little importance. If it is not important to you, than it's good for you..And even that weight is not huge.  For example, the Skywatcher 8" OTA is only 8 pounds lighter than the 10" one. That is what I said: weight is not that much heavier,  but the bulkiness makes it feel heavier. It is not only about weight, but also about shape.
Consider the ease of use for example.  I had the occasion to use a 10" F6 one time.  Though it was a tad harder to move, its eyepiece height was far more convenient for me. Great! This also counts for my 8 incher.
And it was a lovely planetary scope not to put to fine a point on it.  If that one had followed me home, I would have kept it.  It should be remembered also that a 10" gathers a significantly greater amount of light. This is what I said: objects are a bit brighter / bit more detail, but not that much. This is very personal from person to person. I have my meaning and you have yours.  can easily see the difference between my 8" SCT and my 9.25SCT.  My 10" SN at F4 is a stunning sky sweeper.  So deep.
Many of the disadvantages you forward are virtually insignificant or not based on the science or the experience of many users, I disagree on that. Like I said, the information is from many other people with 8 & 10 inch experience. and we probably should not discourage new folks from considering the advantages that greater aperture offers. So, if I tell things about disadvantages, I discourage people. I can say the same thing to you: you discourage people to use smaller aperture. Your statement is about nothing
There are great  reasons to choose either one.  Finally we agree on something.
But again: tell me which of the 10 points are not true and why. So far I have not heard any strong arguments.
Edited by Whiteduckwagglinginspace, 29 March 2025 - 02:51 PM.
#62 areyoukiddingme
areyoukiddingme
Posted 29 March 2025 - 02:26 PM
I have 2 cents to add to other posts which I very much agree with.
When it comes to 8" Dobs, I've had unusually good luck (at least it feels like it).
I travel to see family in Australia once or twice per year, and it's always nice to get a look at the sky going backwards. I travelled with an 80mm apo there a few times, and enjoyed the views, especially going out into rural areas. But always craved more aperture.
One year it occurred to me that the exchange rate was particularly good, and there was an 8" Saxon Dob that I could pick up in Perth on my way down to Albany. First light in Albany with that scope (zero collimation) was on Sirius at about 200x after no time to cool (it was high in the sky, perhaps 70 degrees). Immediate and easy split with the pup. While the star test wasn't perfectly even either side, it didn't matter--it's a very solid scope, and a major upgrade on the 80mm apo for viewing.
Another time I was browsing A-mart, and came across a pile of very nice parts--Zambuto 8" F7, quartz, 20mm, with Antares secondary, a tube, moonlight focuser, and a slightly molested meade cell. The seller was a newbie who had bought the parts of someone else with the thought that he'd put it together to do some astrophotography, but he realized it wasn't a good place to start. I upgraded some of the parts and used it as Newtonian mostly, but also got a Dob base for it. This thing spanks every apo I have (80mm Orion, 92 AP stowaway, Televue 101, Astrotech 125mm, and the old ES 6" apo). Contrast on the planets is ridiculously good.
It would be a lot of fun to compare side-by-side with some premium apos on the planets. I'd be very surprised if it doesn't beat 6" apos. 5" wouldn't be a contest.
  • Arkade likes this
#63 WillR
WillR
  • Loc: Stroudsburg, PA
Posted 29 March 2025 - 03:51 PM
Hi Marinjo. I own a 10” dob, so I’ll address some of your points.
How much more you see is somewhat subjective. I will say that the square of 8 is 64 and the square of 10 is 100, so that is a 56% increase in light gathering, which some people might find significant. I haven’t owned an 8”, so I can’t directly compare.
I don’t use a coma corrector on my 5” and it doesn’t bother me. Are you saying the 10” needs better eyepieces because it is faster?  I don’t think the difference between f5 and f6 is great enough to require a different set of eyepieces. Same goes for collimation. Not a huge difference, but you are right, an f6 is more forgiving.
I don’t think wind or turbulence are a factor in the choice. You wouldn’t notice any difference
That said, your points have merit, but for me aperture won the day. I was debating whether to get an 8” or a 10”, but the price and construction of the 10” won out. No wood, waterproof, breaks down for travel. It is called a hybrid truss dob. At home I keep it on a hand truck, so weight and bulk are not an issue
  • Jon Isaacs and Arkade like this
#64 Arkade
Arkade
Posted 29 March 2025 - 04:12 PM
I have been researching and the weight of the ota is really not much difference, neither is the rocker box much heavier.
I was just thinking, just like any telescope, you always wish you had more aperture. From 8 to 10, that is 50mm , when I look at it like that, it is worth having extra 50mm, who couldnt do with an extra 50mm.
It seems that Ed Tings discussion on 8 vs 10 has swayed so many people into getting an 8 inch.
I saw a girl who was on astrobiscuits channel who was about 14 and not a big and she had no issue moving and reconmending a 10 inch dob. No offence Mr Ting but maybe like our friend who is in his 70s also said, Mr Ting isnt a big guy.
#65 dnrmilspec
dnrmilspec
Posted 29 March 2025 - 04:22 PM
I am not hear to argue with anyone.  I am hear to offer my perspective based on 6 decades of experience.
I have no "strong argument" to what you posted.  You posted a lot of stuff expecting the rest of us to agree.  Some of what you posted, though based in fact, amounts to insignificant differences and so, if they dissuade a new user from choosing a more capable scope, cause unnecessary damage.  Let me give you an example"
You posted that 10" telescopes "are harder to collimate".
This is not necessarily true.  First of all the process is exactly the same.  I think where you are misunderstanding a bit is this.  Tolerances are more important in fast telescopes versus slow ones.  If you look at the Skywatcher catalog (for example) the 8" telescope is F5.9 and the 10" is F4.7.  In theory the 10" faster mirror is harder to make.  Collimation at faster F rations is thought to be a bit more critical.  But again.  The process is the same and it is important for a new person to understand why these assumptions are made.
You said "The 8 inch is sharper to the edges, where the 10 inch can be slightly less sharp to the edges".
This could be true or it may not be.  In fact, often is not.  Again though you are seeing an effect that has more to do with faster scopes than the actual aperture.  Larger scopes are NOT "less sharp".  Faster scopes often show greater field curvature than do slower ones and larger scopes are frequently faster.  In the case of Dobsonian Newtonians the major benefit to a faster scope is convenience.  Shorter tubes are easier to use.
"Scott T:   In a standard Newtonian, field curvature is directly related to focal length. In fact, radius of field curvature is equal to focal length. So an 8" f/6 Newtonian has curved field with a radius of 1200mm, while an 8" f/4 has a field curvature radius of 800mm. Therefore the faster (f/4) telescope has greater field curvature (a more strongly curved field)."
You said, "10" telescopes require more expensive eyepieces".
This is not necessarily true.  Great eyepieces benefit all scopes.  Longer focal ratio scopes are thought to be more forgiving of eyepieces but then they have narrower fields of view.  And that, benefits from very wide field of view eyepieces, which are, by and large, more expensive.  Again, speaking very generally, wider field eyepieces are more expensive no matter what you plug them into.  But in the case of an 8" versus a 10" the difference is insignificant baring the above.
I do not want to belabor too many of these points.  This is the beginners forum.  We do not want to get too far into the weeds here.  The last thing we want to do is dissuade someone from choosing what in this case is a more capable telescope, over considerations that are either incorrect or insignificant to the average visual observer.
  • Jay_Reynolds_Freeman, WillR and Arkade like this
#66 Don W
Don W
    658th Member
  • Loc: Cottonwood, Arizona
Posted 29 March 2025 - 07:35 PM
I happen to agree with dnrmilspec on all points. I have been in this hobby since 1981 and have owned dozens of scopes of nearly every size and type. One of the best observers I’ve ever known has a 10” f/5.6 dob that he built with my supervision in 1983. He has none of the problems you suggest.
#67 Jay_Reynolds_Freeman
Posted 29 March 2025 - 08:12 PM
Since we have started debating eight-inch versus ten-inch Dobsons, I will pipe up again. I have built and made considerable use of one of each, as well as a twelve-and-a-half inch. The eight-inch was first -- it was f/5.1, and was in pretty much the classic style -- solid tube with the balance point nearer the middle than the bottom, plywood rocker and ground board. It did use a conventional mirror cell, since I happened to have one around. The 12.5 was second -- built for a local club using an existing f/6.3 mirror, with similar construction to the eight inch, but with carpet-and-strap mirror support in the traditional "box" with a big Sonotube sticking out of it. The ten was my third and last so far -- f/5.0, truss tube, quite lightweight wooden construction in a more modern style, designed for easy take-apart and airline travel, and by far the most compact when so disassembled. All three had Pyrex mirrors.
I am mostly a deep-sky observer, and all three telescopes worked well for me, the sole problem being that the 12.5 was too big for me to transport since I did not then own a van; I used it in my driveway for a while before turning it over to the club.
The telescopes were generally stored and transported at ambient temperature, so cool-down and associated thermal effects were rarely a problem. I occasionally could detect a pool of cool air on the "down" side of the 8-inch's tube, but it did not affect low-magnification observing, and removing the vinyl cap at the bottom of the tube made it go away when it was a problem with higher magnification.
I never felt the need for eyepieces with particularly wide apparent fields of view with these instruments: A low-magnification eyepiece with an apparent field of view of 65 to 70 degrees gives at least a one-degree true field with any of them, and that is more than sufficient for locating things if you have a decent finder to start with. With the 8- and 10-inch telescopes, I would generally start with a 20 mm Meade Research-Grade Erfle, with a 68 or so degree apparent field of view, and magnifications of 51 and 62 respectively. With the 12.5, I would use a 32 mm Erfle. Those magnifications were as often as not perfectly adequate for deep-sky work, and when I wanted more I would switch to something like a Meade 7 mm wide-field (similar apparent field to an Erfle) or, later, an 8 mm Brandon (45 degree apparent field, more or less). I never used a coma corrector, because when you use an Erfle with a fast Newtonian, the dominant off-axis aberration you see is not the coma of the primary mirror but the much greater inherent astigmatism of the Erfle itself. (Try an old Erfle in a fast Newtonian with a ParaCorr and see what we were up against when Erfles were the best there was.) If I were doing another Dobson I might plan for a ParaCorr and maybe some whizzier wide-field eyepieces -- or not, since I have never been bothered by their lack. And in the 8- and 10-inch instruments I am describing, adding these items as an afterthought would have made the telescopes very difficult to balance: Can you say "Dippy Bird"?  :-)  :-)  :-)
Collimation was never a big deal with these three telescopes: I had to tweak the eight-inch every few setups, mostly because the diagonal support tended to rotate about the optical axis when transported, but the ten survived five nights' worth of tear-down, setup, and transportation between my sea-level hotel in Hilo, Hawai'i, and the Summit Observatories Visitor Center, 9300 feet up on Mauna Kea, with no collimation adjustment required. I stored the 12.5 in my garage while I had it, and merely rolled it out to the driveway to observe; that process was too gentle to mess with the collimation.
Wind did not bother the 8-inch much -- its tube had nearly the same area on either side of the pivot points. The 10 tended to weathercock in the wind with the fabric light shroud installed, but it was stable -- though less well-baffled -- when I took it off. I don't recall using the 12.5 in more than a gentle breeze.
Since the 8- and 10-inch telescopes were both f/5, when I used the same eyepiece in both, they showed nearly identical aberrations at the edge of the field. Note that most commercial 8-inch Dobsons are f/6 whereas most commercial 10s are faster: Comparing edge aberrations for them might favor the 8-inch, both because the longer focal ratio is more forgiving of eyepieces and because the eyepieces required for the comparison would need to have slightly longer focal lengths at 8-inch f/6 than at 8-inch f/5, in order to obtain the same magnification.
The 10-inch was lighter in weight, less bulky, and much easier to operate than the 8-inch, but that was due to my taking advantage of the community's experience with truss-tube types to come up with a better design than I used for the eight-inch.
I hope my experience may be of some use to the topic originator.
Clear sky ...
  • Arkade likes this
#68 Don W
Don W
    658th Member
Posted 29 March 2025 - 08:42 PM
I have this basic rule of thumb.
Anything up to 10” is portable.
Scopes of 12” and larger are transportable.
  • Jon Isaacs, dnrmilspec and Arkade like this
#69 Arkade
Arkade
Posted 29 March 2025 - 10:05 PM
Thank you everyone. The info has been great. I will let everyone know how I get on with collimating my first dob and 10 inch and how hard/easy it was....just need to wait ...thanks everyone
  • Don W, Jon Isaacs, scotsman328i and 2 others like this
#70 scotsman328i
scotsman328i
  • Loc: Charleston, SC.
Posted 29 March 2025 - 10:39 PM
Wow! A whole lotta dust still settling in here. LOL.
Hey, an 8” Dob is fantastic for the reasons everyone listed. A 10 Dob is also great for the reasons everyone listed. Bottom line will depend on if you want a degree of greater light gathering ability, or if you want more portability and less weight to lug around. One will always be a trade off for the other. However, regardless of the direction you go, enjoy the scope and view through it as often as you can. The 8” and 10” are both fine choices. waytogo.gif
  • Arkade likes this
#71 Arkade
Arkade
Posted 29 March 2025 - 10:42 PM
I am only literally 5 feet from my patio to my garden, so a 10 inch can fit through the door and not many steps. If an elder man in his 70s cam carry it, as can a 14 year old girl, im sure i can lol..maybe ed ting needs to start doing some squats, love his channel
  • scotsman328i, areyoukiddingme and BlueRidgeSky like this
#72 scotsman328i
scotsman328i
Posted 29 March 2025 - 10:44 PM
Then a 10” DOB it is!…Enjoy it!
You’ll dig nice and deep into the heavens with it!
  • Arkade likes this
#73 Jon Isaacs
Posted 30 March 2025 - 06:33 AM
You asked which of the above are not true. I would say the following: Which of the above are  significant.
- The cooling is a non-issue. Both need fans, both cool quickly.
- At F/5, a coma corrector is nice but not necessary. At F/6, a coma corrector is nice but less necessary.
- Affordable eyepieces work at F/5, there isn't much difference between F/5 and F/6. The edges will be slightly better in the 8 inch if one is using wide field eyepieces.
- With any Dob, collimation needs to be checked every time is your want the best possible views. Collimation is somewhat more critical at F/5 than at F/6 but still very doable.
- The turbulence/seeing might affect the 10 inch more but that's because it is more capable.  It's unlikely that an 8 inch would outperform a 10 inch. If it did, both views would be poor and it would not be a night for viewing the planets etc
 - I think they'll both be about the same observing in observing in windy conditions. I often observe in winds of 20 mph or even more. The 10 inch has a slightly greater cross-section (20%) but also weighs significantly more (> 30%.)
- In terms of performance, the difference between an 8 inch and 10 inch Dob is the same as the difference between an 80 mm and a 100 mm refractor.  I consider the difference significant, 25% greater resolution, 56% greater light gathering. That's about 1/2 magnitude, that's quite a bit..
The arguments you make for the 8 inch F/6 over the 10 inch F/5 can be used with a 6 inch F/8 over the 8 inch F/6..
I've owned all three. All three have advantages and disadvantages.
Personally, the 10 inch F/5 works best for me. I've owned all three. The size and weight are non-issues for me, they can be for others.
I'm not a salesman trying to sell someone on what I believe to be their best choice. I'm a salesman that tries in inform and educate the customer so the customer can make an informed decision..
  • Arkade and Whiteduckwagglinginspace like this
#74 WillR
WillR
Posted 30 March 2025 - 08:00 AM
Whiteduckwagglinginspace got a bit defensive about his post. I see some of his replies are gone.
There was no need. Everyone can see he was trying to help. The problem with his list is that the individual items weren’t weighted for importance, as Jon points out.
He refers to the aperture difference at the beginning as “seeing a bit more”. Then he gives a list of disadvantages, so the aperture difference is presented as relatively minor. But the aperture difference is the overriding difference, IMO, more significant than all the others combined.
Anyway, the OP has decided on a 10”. I think he will be happy.
#75 Jon Isaacs
Posted 30 March 2025 - 09:14 AM
I hope he will be happy. I suspect the OP would be happy with either an 8 inch or a 10 inch. Both are good, solid capable scopes. It's hard to go wrong with either one.
A couple years ago I bought a year old but unused XT-8 for my friend Felix. It was the right scope for Felix..
On the other hand, my friend Tom bought an XT-10 from one of my friends. Tom and Felix are about the same size, more diminutive. But Tom is able to carry the scope assembled with relative ease..
  • scotsman328i and Arkade like this
