Hello,
I've been naked-eye viewing stars and planets for a long time... decided to go ahead and get a used 8" dob - it came with default plossl 25mm, 10mm and additional 6.3mm and some 2x plastic barlow.
I love the 25mm! But the others are not really fun to use at all due to their small pupil, I don't want to be squinting all the time and I wear glasses as well so it makes it difficult to use them.
I've spent some time reading on the forums, reddit, etc. about all the available eyepieces and what their use case is for various objects, etc.
Still, I am curious what various dob 8" owners have and use on the daily, or what they recommend - I noticed I do have a 2" adapter with the scope - are there any pros or cons of using 1.25 vs 2" eyepieces? What if I were to want to get a larger aperture dob in some years? Are there some overlaps between eyepieces that work for different apertures?
So far, I've narrowed down these options:
Baader Hyperion Universal Mark IV zoom eyepiece + zoom Barlow lens set
This seems widely recommended as the best starter kit you can get for your money with the biggest benefit being convenience. I was seriously considering this one, just because not switching eyepieces seems like a very convenient thing. But ultimately a lot of people recommend just having 1-2 solid pieces such as a 10mm + a 25-30 mm wide FOV one and that for similar money (minus the barlow).
I noticed one user - astro.catshill in his blogpost explains that there also needs to be a 35mm 2" extension that you use if you want to go for this combo. I assume the below extension would work?
Omegon 2“ Extension tube, 35mm optical path - I've heard that if you want to use 2" scopes on the Classic 200P 8" Dob, you might need some additional extension to accomodate the focus (on top of the 2" adapter) - is this true?
Other eyepieces:
Omegon Oberon 32mm 2'' - haven't been able to find any reviews on this online that would give any sort of definitive review. Only some vague posts about it being a copy of another eyepiece and that the 82 fov is actually 70, though the weight of this piece seems overkill...
Omegon Redline SW 32mm 2" cheaper alternative to the above.
Omegon SWA 32mm, 2” eyepiece - similar as above...?
Baader Hyperion 31mm, aspheric - hyperion line from baader seems to get mixed feedback.
Baader Hyperion 13 mm - consensus is morpheus is a better investment, but I doubt I will care much for the more premium lineup considering im moving from the default scopes.
What I also saw was recommended from Chinese options as insanely good for the price (how do these compare to the ones above?):
Angeleyes 70° FMC 14mm 1.25''
Sky Rover 2 inch 70 degree UF 30mm
Though you can add more eyepieces to make a more complete set, I recommend 5 eyepieces that yield 50/100/150/200/and 250x
That would be 24mm, 12mm, 8mm, 6mm, 4.7-4.8mm.
The eyepieces you mention don't all function well in an f/6 scope.
Oberon--same as Celestron Luminos. OK at f/6
Redline 32mm--lots of lateral astigmatism at f/6
Omegon SWA--same as William Optics SWAN, and has lots of lateral astigmatism at f/6
Hyperion 31mm--same edge of field problems
Hyperion 13mm--the worst in the line, with edge of field brightening.
Angeleyes 14mm--a step up in quality.
Sky Rover 2" 30mm Ultra flat field--the best of the entire group you mention. The Tecnosky is the exact same eyepiece. This eyepiece is sold under 8 different labels.
I'd look at (to keep prices low)
Sky Rover 24mm Ultra Flat field for a lower power (or EU brand that is the same eyepiece with a different label)
The Baader Zoom only fills in for a couple more focal lengths.
If you like the idea of zooms, Svbony makes a decent 3-8mm zoom that would fill in for any/all high powers for planets, Moon, and double stars.
