Somewhat reposting from the previous thread, just to get things up to speed here:
First, I’m not in love with it, but it does work.
There is slight vignetting with my 68° eyepieces. However, the 68s are still quite useable and I’ve mainly been using an ES68 20mm the last few times out. My 50°s (Plossls) and my 7-21 zoom were pretty much free of vignetting as tested against both a clear blue sky and at night. 82° eyepieces (most of my eyepieces are 82s) show quite noticeable vignetting though, so 82s are out. This could be a good excuse to get started on a 60° eyepiece set
The Moon really looks great through the 52. I also got nice views of the thin crescent Venus while it was still around (meanwhile, by accident while looking for Venus handheld, I came across Mercury for the first time in a few years!). With a 30mm Plossl, it easily takes in all of the Beehive, the M41 open cluster or the Orion sword area, etc. At relatively high mag (zoomed in with the 7-21 zoom), Sirius did showed a faint blue-ish haze around it, but there were a lot of scattered clouds so that might have been atmospheric, I don’t know yet (havent re-tested that).
It’s not great on double stars at low mag, though that might be due to the Plossl eyepiece I was using in it a lot at first, I’m not sure yet. But some doubles that I could [if only barely] distinguish as doubles in my 9x50 SkyWalker RACI weren’t clearly double in this Askar. Of course, the big difference is that with the Askar 52SD, one can use higher mag eyepieces, too. The Winter Albireo (h3945), for example, showed quite nicely through the Askar using a 3-8mm zoom.
Regarding field curvature, there is some. It wasn’t noticeable at first, but for example, when focusing on the almost full Moon at a mag where the Moon’s disk filled a good portion of the field of view, in trying to get perfect focus, I noticed that perfect focus wasn’t happening everywhere at once. Interesting, as it’s pretty subtle. The field curvature is barely noticeable when starhopping. The problem is, though, focusing in general. It’s a chore. The focusing ring is a bit stiff and, turning it maybe 20 or 30 degrees at a time, I found it took approximately 100 turns(!) to go from one end of the focusing range to the other. This became much less of an issue once I finally figured out approximately where in the focusing range my eyepieces would focus with my two diagonals (different ends of the focusing range for with my mirror and for with my prism), but at first it was quite a chore. Meanwhile, while the rough focus takes forever (if you aren’t in the right neighborhood), for fine focus it somehow seems too sensitive, I guess due to that subtle field curvature. Due to that and having to have the 20mm eyepiece pulled out a bit in the prism diagonal’s eyepiece holder, I just stuck with that one 20mm eyepiece the last three times out (instead of freely switching between eyepieces per my original intentions for this scope).
I was freely switching between eyepieces when I used the mirror diagonal, but I want to use this with a prism, I think. Gotta wait for those spacer rings I ordered to get that all straightened out.
Also, I want to look into getting a secondary tuning helical of some sort, like maybe something on the eyepiece end. Finally, I’m going to look into other mounting strategies (I’m not thrilled with the 3 screw single clamshell-like holder).
Will try it on my Dob at some point, too
