Roberto and Frank, thanks for the feedback.
...I think the Icron is overpriced unless it has some capability I'm not aware of.
Yes, at the standard retail price of just over $1000 the Icron Raven is more than I'd want to pay. However, as I noted earlier these same units seem to be available at a much lower price on eBay, used versions can run about $300 and new units seem to be available for much less than $1000. This means that you might be able to find one for less than Frank's (freestar8n) optical USB3 Gen 2 cable once you add a good 10Gbps USB3 Gen 2 hub to the latter. And I think I'd rather buy a used, wired version of anything over an optical cable if both need to be run outdoors.
That said, those optical USB-C cables carrying 10Gbps are something that I did not know about. I knew about such cables for Thunderbolt but not USB-C. However, the device that Frank linked to will not support USB v1.1 so perhaps no keyboards, etc, although I'm not aware of any of my astro equipment that would require USB v1.1 (but, don't know about a serial converter since USB v1.1 at 12Mbps would be plenty fast enough for a serial port -- do serial converters run over USB v1.1 or v2?).
However, if you had a permanent setup and could protect the optical cable when run outside then that device could be the “best” solution in terms of both cost and performance.
As for the Icron, its only obvious advantage over the less expensive USB3 extenders is that the Icron also supports a 1Gbps ethernet connection in addition to the four USB3 ports. So, it has five data ports all carried over a single cat 6a cable (total bandwidth consumption approximately 6Gbps). But, if you look at the marketing for the AV Access extender is says that the "Data transfer rate [is] 1E+1 Gigabits Per Second." I'm not sure what that "1E+" is supposed to mean but the following "1 Gigabits Per Second" COULD be an indication that the link between the sender and receiver is only running at 1Gbps (i.e. similar to the standard ethernet 1Gbps). However, that doesn't really jive with their claim of support for 5Gb USB3. Meanwhile, Icron says that their link is running at 10Gbps. If the AV Access extender has a link that is limited to 1Gbps then it may only be about twice as fast as the much less expensive extenders that support 480Mbps transfers over USB2. I already own one of the latter (an E-SDS USB2 extender) that I purchased for $50 about four years ago and I recently retested that device and got 40MBps (that's 400Mbps) from a Samsung Pro Plus SD card that is rated at 100MBps/800Mbps. Thus, the USB2 extender is getting pretty close to the rated USB2 speeds.
This is one of the reasons why I'm wondering about the actual data rates from both the AV Access and the OREI extenders. Is their link rate through the ethernet cable 1Gbps, 2.5Gbps, 5Gbps, or 10Gbps or something else like "1E+1?" In any case, the fastest of all of these device might be the 10Gbps optical cable suggested by Frank since in theory that might provide peak rates of up to 10Gbps right to the USB-C plug on the end of the cable and adding a true USB-C 10Gbps hub to the end of that might give you a peak data rate close to that same 10Gbps (to a single device and only if the sender was capable of 10Gbps).
Somewhat oddly, I can find no true reviews on any of these products, just stuff that appears to be restatements of the marketing materials from the manufacturers. Perhaps I need to reference the manuals that come with the AV Access and OREI extenders, although I suspect they won't have much additional technical information.
One other thing I'd like to know about the Icron unit is whether their 1Gbps ethernet pass through is totally transparent and protocol neutral. Thus, does it only handle ethernet protocols or does it act just like a straight-through cat 6 cable. If the latter then it might be possible to attach my existing USB2 extender to the ethernet ports of the Icron units. This would allow another four USB ports without having to use a hub on one of the Icon's four existing USB3 ports. Frankly, I don't think this would work since it's almost certain that the link between the extenders isn't really running over a true ethernet protocol (i.e. it's probably a proprietary, "raw" data stream) while the Icron probably expects to see an ethernet protocol at its input port. But, this may be something that I can check in either the manual or from Icron support.
Icron also makes quite expensive USB2 extenders so it seems likely that someone, somewhere has asked if you can attach one of those to the Icron Raven's ethernet port. So, it might be possible to find someone at Icron who knows enough about their products to answer this question, but it probably won't be easy to find that person and as I've already suggested it almost certainly won't work. However, if it did then that would be another item in the Raven's favor.
Edited by james7ca, 29 March 2025 - 02:07 AM.
