Recently started experiencing guiding issues, and I'm having trouble nailing down what's happening. I've been running this mount since January, and guiding has been relatively good but over the last few weeks I've been seeing start trails due to an RA correction that is creating star trails on 50%+ of my subs.
I started with the default settings on the ASIAIR+, and just changed the exposure settings from 2s to 1s or 0.5s to try and improve guiding. I recently tried with a different guide camera, but the issue still persists leading me to think it's something else.
I've made sure that everything is tightened down on the scope, guide camera, and cameras themselves. Cable management is good and isn't snagging on anything. Polar alignment is typically under 3" error based on the ASIAIR PA routine.
Equipment Details:
- AM5N
- ASIAIR+
- ASI2600MC Pro
- RedCat 71
- WO 32 Uniguide 120mm
- ASI120MM Mini (guided well until it started these issues)
- ASI715MC (new camera, tried to use this to see if there would be any improvement.
Typical Exposure Settings:
- 180s at 0 gain
- 300s at 100 gain (dual band filter)
Guiding Settings:
- Calibration Step (1800ms)
- Max DEC Duration (500ms)
- Max RA Duration (500ms)
- Auto Restore Calibration enabled (I did try to disable this for a while and force a calibration on every guiding, but didn't get improvements.)
- Guide Stability 2", 5s, 60s timeout
- Dither 5px, interval 2
- Dark Library enabled for ASI120MM
- Corrected trigger Acc. 0.1px
- RA Aggr - 70% (left this at the default)
- DEC Aggr - 100% (left this at the default)
The AM5N was set to 0.25x tracking rate, and I changed this to 0.5x to see if it would help but had the same issues.
Attached my guiding logs from a good session (2025-03-08 and 2025-03-12), and then from 2 sessions where it just got terrible (2025-03-14 and 2025-03-25)
https://drive.google...UBb?usp=sharing
Here's a screenshot from PHD2 Log Viewer with the RA showing some crazy changes.
