Background story: I had posted earlier about purchasing a COMA helical focuser from Lolli Adriano to replace the stock helical focuser on my LUNT 40 Ha solar scope.
COMA Focuser "made for Lunt 40mm" Problem - Solar Observing and Imaging - Cloudy Nights
I hoped that this new helical focuser would have more in-focus and would be more physically robust to support using a binoviewer without sagging. The initial unit I received earlier this year (2025) was sold to “fit the LUNT 40” but had M52x0.75 threading that did not match my LUNT’s M52x1.0 on the OTA. I notified Lolli Adriano about the mismatched threading. Apparently, an earlier customer from Germany had insisted the finer M52x0.75 thread was needed for their LUNT 40. This was strange since LUNT communicated to me that they have only used the M52x1.0 thread on the OTA for attaching the focuser. In the end, Lolli Adriano now has available the COMA helical focuser for the LUNT40 in both the M52x0.75 and M52x1.0 versions.
First Impressions and Installation: I received the new COMA helical focuser with the M52x1.0 threads. The range for the stock helical focuser from the OTA to the blocking filter was ~55-65mm. The COMA unit was ~52-78mm. On first approximation, there would be at least 3mm more in-focus which would be a great help for using more powerful eyepieces with my binoviewer. In actuality, the new COMA focuser mated very nicely with the OTA so I think I may have gained ~4-5mm. Also note that the COMA focuser has a wider diameter which may contribute to making it easier to rotate. There are also three thumb screws to hold the blocking filter instead of the single thumb screw on the original focuser. Here are some photos to show the differences.
The COMA focuser rotates much more easily than the stock unit. I cannot say that the rotation is “silky smooth”. The action has a faint metal-on-metal feeling/faint sound. I tried wiping out the oily lubricant from the inside of the extended unit and then added some Super Lube. This helped but did not eliminate the observation. I’m guessing that the machining tolerances are just very close and this will not be a negative issue. Maybe all helical focusers have a little bit of this type of action?
Lastly, I threaded the new COMA focuser into the OTA using No. 567 LOCTITE thread sealer as others had recommended elsewhere on the Cloudy Nights forums. Just to be safe, I let the OTA with the focuser stay open (didn’t add the blocking filter) for a few days to air-out any fumes.
In my next post, I’ll provide my in-use assessment of the COMA helical focuser on my LUNT 40 Ha solar scope. Preview was that is works very well!
Blue and sunny skies,
Clark in Madison, AL
Edited by Clark@Night, 26 March 2025 - 12:43 PM.
