With the D750, unmodified and the D5300, Ha modified, I wanted what would give me the largest field of view. I have the Askar FMA135, but it is limited to APS-C cameras. My FRA300 says it will do full frame,
"With a 60mm triplet objective with an ED element and a two-element corrector, this f/5 scope has a focal length of 300mm and makes an ideal instrument for capturing stunning wide-field images of the deep sky over a 44mm full-frame image circle."
Unfortunately the Askar FRA300 has limited back space for a DSLR, so no room for a filter drawer. From the manual:
There was a way to mount a 31mm filter in an adapter inside the camera adapter ring:
The 31mm filter was not good as it reduced the flow of light to the camera and resulted in vignetting.
Next issue: The CCD Suitability Calculator says this scope needs a smaller pixel size, significant under sampling.
And the D750 as unmodified won't be good for nebulae even with a filter, as an unmodified camera has a blocking filter before the sensor.
So I guess I should try these cameras with my large focal length telescopes, which like larger pixels according to the CCD Calculator.
It's too bad because the D750 was giving 6.88 x 4.6 degree images and the D5300 4.5 x 3 degrees with the Askar FRA300.
Any suggestions on what combinations or approaches to get the most out of these cameras? Thanks!
Edited by Sky King, 26 March 2025 - 12:02 PM.
