I'm sure I'm not the only person to attempt this. Feel free to add to the post, regardless of which smart scope you use!
Arguably, it is cheating, since we are using the telescope to automagically find and image each object. But there is still a lot of manual effort involved, since local circumstances (trees, clouds, etc.) will require you to adjust your schedule on the fly. I started with the schedule at https://www.messier-...ssier-marathon/, allocated 3 minutes per object (to allow for a 3-hour break at midnight) and adjusted as needed. My adjusted schedule is at https://docs.google.com/spreadsheets/d/13wv0y3jeXpS2cxoY4p5cuA1Zykqhtx0W/edit?usp=sharing&ouid=105375012512636970462&rtpof=true&sd=true - I calculated rise/set times and az/alt at my scheduled times to help with scope placement as well as schedule tweaking. I did a lot of tweaking around due south since there was a large tree that direction - I did not stick strictly to the schedule.
This is with a Celestron Origin. The exposures vary widely because of networking glitches, trying to keep up with the schedule, etc. I did manage to get a 2-hour break in the middle to get a little shut-eye. Images with an asterisk '*' were partially or almost completely obscured by trees / dusk / dawn / etc.
300 PPI poster is at https://photos.app.g...vCfvxSkb1S4BWt7
Edited by racunniff, 27 March 2025 - 11:27 AM.
