Hello:
I have a SW 80ED that I use for imaging. The issue is that despite repeated attempts at tuning up the stock focuser I am losing nights to bad focus (N.I.N.A). I have decided that I will upgrade the focuser as clear nights are too rare and valuable to lose to a poor focuser.
My existing imaging train is as follows - from the SW drawtube is threaded on the SW 80ED 0.85x reducer with a M56 x 1 thread. A ZWO 8 position filter wheel is attached via adaptor to the reducer and a ZWO 1600MM is attached onto the filter wheel. Focus is achieved using a ZWO EAF. All of the listed equipment will be used with the new focuser.
I'm looking at the FLO focuser here - the Astro Essentials v2 2" Dual-Speed Crayford Focuser for Sky-Watcher Refractor Telescopes. It has a M54 x 0.75 female thread on the drawtube. FLO's website for this focuser states "Our Astro Essentials Adapter will enable you to use Sky-Watcher focal reducers with this focuser." The adaptor does not have its thread sizes listed although one of the comments alludes to it having an M56 x 1 thread, which means it would fit my SW reducer. However, this adaptor would simply slide into the focuser and be held with grub screws. It doesn't give me a warm-and-fuzzy feeling and a youtuber seemed to experience camera tilt due to this arrangement.
A bit of digging revealed that there is an adaptor that seems like it would allow for a solid, threaded connection between the reducer and the focuser. A company called RAF Camera sells an M56 x 1 male to M54 x 0.75 male adaptor. In my mind this would allow for a solid connection.
What I'm looking for is a second set of eyes to check my work and make sure I'm not missing a better path for focuser replacement. Thanks in advance.
