- the scope has to be short enough to be inexpensive.
I'd prefer 3inch ED telescopes like Vixen SD81SII. The focal length 625mm is suited for those of Ha nebula, and several large galxies.
and it is up-gladable as more wide field and fast photo lens. or it can be used as both visual and photo.
Fast enough to tolerate less-than-perfect mount tracking.
It requires very fast F2.8 400 mm class lens, or short 180mm class lens. Cat 71 WIFD is F4.9 350mm, not easy to take pinpoint stars with no guided mounts. If you'd consider lucky imaging method, it also requires Fast F4 to 6 class lens and telescopes. F7 class tend to be noisy.
It also has to be long enough to have some kind of reasonable image scale with one of the newer, less-expensive cameras.
It's better to use with APS-C class camera or 4/3 camera. If you'd hope to use with full 35mm size camera, the telescope price will be tremendusly high. and it's must to use with filter modified camera. To purchace a used modified astro camera is best way. Canon 6D or 60Da is most popular and standard.If you use 6D, crop out the fringe area of fat image with large coma and as. I don't think newer miror less camera is best way to choice, except Sigma FP or FPL.
Ideally, it has to be simple enough as not to be maddening in use. It's helpful if the image isn't disappointing (except as I may make it).
Fitst of all, try it, fail it and recover it. Expeience is a good teacher. The images is only depends on the lens design. You can not recover. Disapointing or not? it depends on the personal boarder bar. You can't say it's enough or not on some one.
In my experiences, Sigma 40mm F1.4, 70mm F2.8, 135mm F1.8s are the best lense as full frame image circle with pin point stars. About for the 300mm class, Canon 100-400 F4.5LII also the best lens. Canon EF 300mm f/2.8L IS II is discontinued, though not high as EF 400mm f/2.8L IS III in used market.
It's better to try first with your already owned camera and lens. Experience will tell you the way to next.
Edited by n2068dd, 01 April 2025 - 08:51 PM.
