Thomas can you provide the model #'s? Objective Diam and FL.
Don
For many years, from around 1908 to 1940-ish, they made achromatic E lenses and apochromatic B triplets in the following, standardized dimensions:
60/850mm
80/1200mm
110/1650mm
130/1950mm
150/2250mm
200/3000mm
From 1926 onwards, they also made AS doublet semi-apos with the same specifications.
The intention was that you could buy a telescope with an achromatic objective, and then later change to an apochromat, if so desired.
The AS lens replaced the A doublet apochromat, which had a different focal length and wasn't interchangeable with the E and B objectives.
After WW2, it took until 1972, before Zeiss offered an achromat and a semi-apochromat with the same aperture, namely the C63/840mm achromat and the AS 63/840mm semi-apo. It wasn't until 1986, with the introduction of the APQ 100/1000, you could once again buy a true Zeiss apochromat. It shared the same OTA with the AS100/1000mm semi-apo.
Clear skies!
Thomas, Denmark
