Easier eye placement than XW, and wider AFOV than Delite?I use Baader Morpheus 4.5mm and 6.5mm, preferring both to the XW and Delite.
Tele Vue DeLite vs Pentax XW Series Eyepieces (7mm, 5mm)
#26
Posted 05 April 2025 - 11:27 PM
#27
Posted 06 April 2025 - 04:09 AM
Yes and yes
#28
Posted 08 April 2025 - 12:31 AM
Wider AFOV than Pentax XW as well
#29
Posted 08 April 2025 - 08:09 AM
AFOV, sure. Field stop, yes on the 4.8M vs 5XW. But the 7XW has a wider field stop than the 6.7M. Granted, the 7XW is lower magnification, so it’s basically a wash.Wider AFOV than Pentax XW as well
#30
Posted 08 April 2025 - 06:57 PM
AFOV, sure. Field stop, yes on the 4.8M vs 5XW. But the 7XW has a wider field stop than the 6.5M. Granted, the 7XW is lower magnification, so it’s basically a wash.
I sold my XW after getting the Morpheus, but have a Pentax XL (& Vixen LVW 8mm).
#31
Posted 08 April 2025 - 09:58 PM
I have some pairs of XWs but 10s and am used to observing solar system with them.
Bought a couple of DeLite 11 at NEAF, hoping they will fill the gap perfectly.
#32
Posted 08 April 2025 - 10:00 PM
Well sure, they work better for you than the short FL XWs in terms of eye placement, and the view is wider (4.8) or as wide (6.7) relative to the focal length.
I still have some LVWs myself. I agree they have very easy eye placement, like Nikon SW. The Morpheus are the same style so I would think they would have easy eye placement as well, and that's their reputation, although I don't have them (I feel like they are too similar to my LVWs).
#33
Posted 09 April 2025 - 01:08 PM
LVWs being hard to replace now, mine are snuggled away in semi-retirement and six Morphei + a 30 UFF are my "Magnificent Seven" now- no undercuts on any of them.
#34
Posted 09 April 2025 - 07:14 PM
Here is my two cents:
Over the past year I've used my old Pentax 7mm XW, a 7mm Nagler Type 6, a Nikon 7mm SW, a Delite 7mm, and a Morpheus 6.7(?) mm. I kept the Pentax, the rest are gone. Much has to do with the structure of your face, eye socket, eyes, and general aesthetic preferences--it's not just a matter of numbers. I found the Pentax easier to use.
Dark, clear, calm skies.
Jack
#35
Posted 11 April 2025 - 04:09 AM
As of 2025 the Delite price is $268 and the Pentax price is $266 so basically same price range.
I also wonder which one is better.
#36
Posted 11 April 2025 - 08:37 AM
I'd definitely want a Pentax XW over a Delite and a Delos over Pentax XW. I ended up buying the 2 Pentax XW's I thought were best (7 & 10mm) and one 8mm Delos. I'd like to add one more Delos but not sure which one. Sometimes I feel like selling everything I have under 12mm and getting a Leica Zoom. That's when I shut down the computer and go away to forget that thought.
#37
Posted 11 April 2025 - 10:27 AM
A question for those that would choose a 70° XW (or other 70°-ish eyepiece) over the 62° DeLite. Would you be using a coma corrector with any of these? Something I see a lot around here is the thought process "I'll use a coma corrector with a 70° EP but not with a 60° EP". I'd opt for using a DeLite without a coma corrector vs an XW with one. Just my 2¢. The image below shows the result of using an XW with a Paracorr (1.15x mag) vs a DeLite without.
#38
Posted 11 April 2025 - 10:52 AM
The DeLite in my mind is better thought of as a modern long eye relief version of minimum glass eyepieces with no compromises that become necessary to get the wider field of other alternatives.
I use the DeLite for lunar and planetary and the Morpheus (formerly XW) for everything else
Just my 2c
#39
Posted 11 April 2025 - 11:04 AM
If you MUST have wider -Delos.
#40
Posted 11 April 2025 - 05:55 PM
Looks like you put in 1.5x barlow instead of 1.15x.A question for those that would choose a 70° XW (or other 70°-ish eyepiece) over the 62° DeLite. Would you be using a coma corrector with any of these? Something I see a lot around here is the thought process "I'll use a coma corrector with a 70° EP but not with a 60° EP". I'd opt for using a DeLite without a coma corrector vs an XW with one. Just my 2¢. The image below shows the result of using an XW with a Paracorr (1.15x mag) vs a DeLite without.
#41
Posted 11 April 2025 - 05:56 PM
Amazon it is $266 for the 1.25 ones Pantex. 10mm 7mm 14mm 20mm
The 2 inches Pantex one is $450 16.5mm and 23mm
The price is expensive, I think I have no choice but pass.
Edited by MrsM75, 11 April 2025 - 05:59 PM.
#43
Posted 11 April 2025 - 08:43 PM
Cheapest entry into premium.
But there are other great alternatives out there.
Like 7 and 9mm Celestron X-Cel LX
Check for the ones marked in yellow here: https://astro--talks...hl=en-US#p41976 or other similar ones for your type of scope.
Edited by Procyon, 11 April 2025 - 08:44 PM.
#44
Posted 11 April 2025 - 10:14 PM
When I got to 5mm, I bought a DeLite and a Pentax XW and compared them. Neither was sharper than the other, but the Pentax was sharper for a wider view, easier to use place my eye over, more comfortable, and more uniform across the view. I was happy to unload the DeLite for almost what I paid. The experiment was well worth the small cost and hassle. I've been happy with the Pentax 5XW and its 10 and 20 siblings for years.
Val
#45
Posted 12 April 2025 - 12:06 AM
I don't know why people are comparing an XW with a Delite? Should be a XW and Delos.
#46
Posted 12 April 2025 - 12:26 AM
Between the XW and the DeLite, while I really don’t think they are in the same group of eyepieces, if you can only have one the XW is really hard to beat for the price. If I only had Delites I’d probably find myself wanting something wider often…
#47
Posted 15 May 2025 - 06:33 PM
I'm saving money to get my first premium eyepiece, lol. And I'm torn between Delite and Pentax XW.
I have the Pentax XF 8.5mm and 12mm, and my Maks love it.
I want to try the XW line.
But then it vs. Televue, who could beat Televue.
#48
Posted 15 May 2025 - 06:38 PM
Val
Do you wear glasses Sir? What scopes you use for the XW Sir? I am leaning toward the XW
The only Televue experience I had is the 32mm Televue Plossl price $177, and No, returned. Massive blackout, my Maks get very fussy with the blackout of the 32mm Televue Plossl, it was very hard eye placement.
But then my Maks love the $40 Vixen NPL Plossl 30mm
#49
Posted 15 May 2025 - 07:45 PM
If you don't wear glasses with a TV32 plossl you need to ad a blank diopt. adapter to cut down the E/R.
#50
Posted 15 May 2025 - 07:52 PM
Vixen NPL 30mm Plossl has 24mm eye relief
Televue 32mm Plossl has 22mm eye relief.
Surely the Televue Plossl has shorter eye relief than the Vixen Plossl. But somehow my eyes very fussy with the Televue, blackout everywhere, super hard for me to get my eye position right.
Vixen Plossl is very comfortable, regardless of how I look into it, there No blackout anywhere.
Also tagged with one or more of these keywords: Eyepieces, Accessories, Equipment, Tele Vue
Equipment Discussions →
Refractors →
Astro-tech 72edii Doublet Refractor f/6Started by phatotis , Today, 01:09 PM ![]() |
Eyepieces →
Baader Classic Ortho 6mm ReassemblyStarted by Reddery , Yesterday, 12:18 PM ![]() |
Reflectors →
Takahashi Epsilon 160 Classic for Digital AstrophotograhyStarted by astrotorben , Yesterday, 11:52 AM ![]() |
Mounts →
Skywatcher 150i, loosens Locking declination screws after run.Started by Scuba2do , Yesterday, 10:04 AM ![]() |
Refractors →
Lost screw in micro focuserStarted by cyberduck , Yesterday, 09:39 AM ![]() |
