Still working on the collimation but with little progress.
First, I shimmed the gap between the cell and the lens elements with thin pieces of paper, so that the elements are better centered. They were not bad to begin with as the gap was not very much.
Then I put the OTA in a mount and focused on an artificial star. The defocused image looks like this, with a large asymmetrical flare.
Then I slowly rotated the OTA within its rings, and noticed that the flare moved in the same direction with the rotation. So this tells me (i think) that this a tilt issue of the cell.
Since the cell is a screw-in type it is not collimatable. But to get some way to adjust the tilt, I loosened the cell from the OTA (a couple of turns) so that it droops a little bit due to gravity. I then rotated the OTA within the rings as before hoping that at some point the star image will propitiously get better as gravity changes the tilt. But that did not happen. I also tried to tilt the objective by hand carefully, but still the flare refused to go away.
Edited by sunrag, 03 May 2025 - 06:44 PM.
