Televue doesn't want you messing with the collimation, in the long run would cause more trouble than not.
The current three screws are covered with epoxy, the same could be done with the adjustment screws. With the three additional screws, it would be more robust, less likely to be knocked out of collimation.
TeleVue would also benefit, from what I understand, they collimate by hand rather than using a fixture. One advantage of a fixture is that the objective cell is held in place while tightening the current three screws.
I believe there is room in the current cell to drill and tap a set of adjustment screws. As I said, when I built my collimation fixture, I considered it. At that time I had a close relationship with some highly skilled machinists who would have done the actual work.
I agree with NGC 7319-20, a more "clever" solution is needed. As he said, the majority of TeleVue Petzvals he has tested at star parties are not collimated.
If a trip to a star party is too much for the collimation, that's not good. My NP-101 has traveled over 15,000 miles in the bed of a pickup, suffered one nose first tumble, it's still in collimation.
I attribute that to the fact that it was collimated using a fixture so the collimation could not shift while the screws were being tightened.
Edited by Jon Isaacs, 12 April 2025 - 09:31 AM.
