I had a couple of minutes so I reassembled the focuser. It went together so quickly I didn’t have time to photograph the process, but as they say, “assembly is the reverse of disassembly”, and I do have some thoughts I can share.
1. The large balls are the first items to reinstall, followed by the fine focuser shaft, and before you slide the fine focuser housing over the large balls and their cage. Make sure the groove in the fine focuser shaft is captured by the large balls.
2. Slide the fine focuser housing over the large balls and their cage. Now you’ll have room to install the small balls on the other side of the housing. My small balls were magnetized and would have been difficult to place, but fortunately I have a set of non-magnetic tweezers which made placing the small balls in their races fast and easy. Most stainless steel tweezers should be non-magnetic.
3. With the large and small balls in place it’s time to thread the slotted adjustment/retaining ring into the fine focuser housing. You want this as tight as reasonable without making turning the fine focus knob overly resistant. Too loose and your fine focuser knob might slip; too tight and you might find the fine focuser action too stiff. You can check progress as you go along if you install the fine focuser knob on the end of the fine focuser shaft.
Tasks 1 through 3 took less than two minutes, and there was nothing difficult or challenging about it. The rest of the assembly was even easier.
The end result is that the focus action, both fine and coarse, as as good or better than new; as in nearly Feather Touch focuser smooth. That’s the good news. The bad news is that the rack teeth were damaged right where most focusing is done on an AT72EDII, which makes for a rough spot right where you want things to be perfect. Here’s what the rack looks like:
This is my third time working on smoothing a planetary fine focuser shaft and the results have thus far always been the same: focuser action is restored to like new or better. If you have a two speed focuser with gritty or notchy action it’s quite possible that you can improve its function dramatically with an electric drill, a bit of scrap fine emery paper, and a chopstick.
