I have the AM5 mount. I am looking for APO triplet refractors in the range of 900mm for deepsky imaging, with a max of 8 kgs? what options do we have?
i could not come across anything other than ES 127 ED FCD-100.
Posted 12 April 2025 - 08:35 PM
Posted 12 April 2025 - 08:52 PM
Go bribe someone and get a FC-100DL
Posted 12 April 2025 - 09:05 PM
Askar APO 120 is 840mm with its 1x flattener, also has a reducer, and weights 6.5kg according to specs.
Posted 13 April 2025 - 01:29 AM
Edited by 900SL, 13 April 2025 - 01:32 AM.
Posted 13 April 2025 - 01:44 AM
Vixen SD115 SII. (Updated version). Doublet but well corrected. Weighs around 6kg including rings
Thank you. Would there be visible quality difference between imaging in Doublet vs Triplet?
Edited by Sreesha, 13 April 2025 - 01:44 AM.
Posted 13 April 2025 - 02:48 AM
For imaging you definitely want a triplet inside your budget range.
Posted 13 April 2025 - 04:04 AM
How about a Takahashi TSA-120? Triplet, f/7.5, focal length = 900. I have never used one, but they have a tremendous reputation. Weighs 6.7 kg.
Posted 13 April 2025 - 06:17 AM
@Osbourne one-nil
@dave novoselsky
There's not much on AB but this image of M3 convinced me Vixen have got a great doublet here.
https://app.astrobin...115sii?i=tf528v
More here
Edited by 900SL, 13 April 2025 - 06:22 AM.
Posted 13 April 2025 - 09:40 AM
I have had two of those:
and they both were outstanding from an optical performance standpoint, unlike the smaller 103 APO I also tried. The focusers on these scopes can be problematic, but they can be adjusted to make them work almost as well as the dual-speed rack-and-pinion focusers on the Kunming United Optics-made refractors, e.g. Astro-Tech, TS-Optics, Altair Astro, etc. There is a thread here on CN about how to perform the focuser adjustments on the Askar 103 and 120 APOs as they share the same tube and 3.3" focuser. Although these scopes do not have fully-rotating focuser assemblies, they do have really sturdy Camera Angle Rotators at the end of the drawtube with a nice 360° scale:
My Askar 120 APO loaded up with a 9x50 RACI, a 2" Baader Silver Mirror diagonal and an 18mm UFF eyepiece came to 17.4 lbs., or 7.9 kg. I suspect that with a camera sensor, an EAF and a guidescope installed the overall weight would be very close to the same as far as the mount is concerned. That 6.5 kg figure is for the OTA with tube rings and dovetail rail.
Edited by Oldfracguy, 13 April 2025 - 09:43 AM.
Posted 13 April 2025 - 10:32 AM
You can certainly go over 8kg with that mount. Example the AT130EDT is 8.6kg. I use it on my AM5
Ohh great to see the AM5 mounted on THAT tripod. I have one as well but have not gotten round to changing the threaded rod to make it work with other things.
The 8kg could be a personal limit rather than a mount limit :-)
Posted 13 April 2025 - 10:48 AM
Yep, as I get older, 8kg is starting to feel like 20kg when I was younger.
The PE200 and M15 threaded rod combo works really well with that tripod. It's a very sturdy setup.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
