Need some help with this...perhaps some of you have found a way to make this work.
I have zero experience with refractors. Maybe, a little bit. A few nights ago I took out a 100mm Orion Astroview Deluxe f/6 600mm focal length refractor. I replaced the nosepiece of a 2" Baader Clicklock Diagonal with a TSFLAT and a 2" to T2 adapter. It made the view through a 31.5mm Antares 90 degree eyepiece feel Nagler like. Fantastic widefield view at 20x and 4.7º AFOV.
I had brought a small case of 2 Pentax XW's (7 & 10mm) and an 8mm TV Delos to try instead of the 2 lbs hyperwides. I could not reach focus with any of the 1.25" eyepieces inserted into an Antares 2" to 1.25" adapter.
Can someone explain to me why that is and how to work around it? If I were to use an eyepiece such as the Morpheus with it's 2" sleeve, would that have worked? Or should I get some light weight 2" eyepieces instead?
Could be an excuse to get the T4's I love again....but yeah, that's a lot of money.
I found this post, but not what to make of it.
https://www.cloudyni...ner-for-visual/
Last Fall I did a test with all my 2" eyepieces, and some 1.25" eyepieces as well, in order to figure out exactly where their focal planes were relative to the flange on the barrel that rests against the diagonal. When I do these eyepiece comparisons I start with a simple 1.25" eyepiece, a 12mm Plossl, whose focal plane is even with the flange on the barrel. I then focus on a distant target over a mile away. When, after switching eyepieces, I have to rack the focuser farther outward to regain focus on the same distant target, that means the focal plane of that eyepiece is down lower than the flange. The Tele Vue Nagler Type 6 eyepieces are a prime example, where I usually need to rack the focuser outward another 8-9 mm compared to a lot of other 1.25" eyepieces. Long focal length 1.25" eyepieces like 25mm and 32mm Plossls need the focuser to be racked farther inward, which means their focal planes are up above the flange.
When checking 2" eyepieces, I still start with the 1.25" 12mm Plossl in the 2" diagional, but I account for the thickness of the particular 1.25" adaptor I'm using in the 2" diagonal. When I was testing an Orion 38mm Q70 (same as the Agena 38mm SWA) I moved the focuser perhaps only a millimeter or so after removing the 10mm-thick 1.25" adaptor. That told me the focal plane of that 2" eyepiece was pretty far up inside, about 11 mm or so above the level of the flange on the barrel that was in contact with the top of the diagonal's 2" eyepiece holder.
