Anyway to add 2 speed to focuser?
13 replies to this topic
#1 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 14 April 2025 - 07:18 AM
Is there anyway to add a 2 speed focuser on my W/O 110 APO?  Very nice over built focuser but with such shallow focus a 2 speed would be nice.  This is a 4" focuser.
Edited by CHASLX200, 14 April 2025 - 07:19 AM.
  • Exnihilo likes this
#2 weis14
weis14
  • Loc: Midland, MI
Posted 14 April 2025 - 09:46 AM
I don't know of a solution for that particular focuser.  One old trick is to increase the diameter of the focuser knob, which can help by making the adjustments easier.  Otherwise, there is always the potential to get an aftermarket focuser, but that would come with a very high price tag for a 4 incher.
#3 Jon Isaacs
Posted 14 April 2025 - 11:40 AM
I imagine it had a two speed at one time. I would contact William Optics.
#4 CHASLX200
CHASLX200
Posted 14 April 2025 - 06:01 PM
No the scope did not have a 2 speed option back in 2004.  Maybe a fine helical 2" focuser that slips in the 2" part of the focuser if such a thing is made?
Edited by CHASLX200, 14 April 2025 - 06:10 PM.
  • Starsareus likes this
#5 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 14 April 2025 - 08:07 PM
I have a two speed WO focuser.  What is the diameter of the tube.
#6 Exnihilo
Exnihilo
  • Loc: Phoenix, AZ
Posted 14 April 2025 - 08:21 PM
That’s a Megrez 110?  How does it compare to the 90?
#7 Lagrange
Lagrange
  • Loc: North West England
Posted 14 April 2025 - 08:47 PM
You could put something together using Borg components that would give you very fine focusing with the ability to use 2" accessories but it wouldn't be cheap - around $394 all-in.
The part numbers you'd need would be:
7425 - 2" nosepiece to M57/60 Adapter
7761 - M57 Helical Focuser DXII
7505 - 2″ Eyepiece Holder (M)
Ted at Astro Hutech could help you out if you wanted a setup like this.
Baader also make some combination eyepiece adapters with built-in helical focusers but they're 1.25" only and relatively basic in comparison.
Edited by Lagrange, 14 April 2025 - 08:48 PM.
#8 Jon Isaacs
Posted 14 April 2025 - 09:12 PM
Can you take a photo or two of the underside of the focuser...
I wonder if Starlight even made a 2 speed upgrade for the scope??
#9 CHASLX200
CHASLX200
Posted 15 April 2025 - 05:52 AM
110mm F/6.5 FLUROSTAR.  Has a Tec lens. Seems better than the 90 was.
#10 CHASLX200
CHASLX200
Posted 15 April 2025 - 05:53 AM
I will look into it.
#11 CHASLX200
CHASLX200
I can get some pics later.
  • Jon Isaacs likes this
#12 Jon Isaacs
Posted 15 April 2025 - 07:01 AM
With a little engineering and some machining, it can be possible to adapt a two speed to an existing focuser.  This is probably the only JMI RCF with a GSO two speed..
#13 CHASLX200
CHASLX200
Posted 15 April 2025 - 06:27 PM
Well that is something i won't be doing.
#14 maniack
maniack
  • Loc: SF Bay Area
Posted 15 April 2025 - 11:49 PM
Or a bit of 3D printing to add a reduction gear to an existing focuser.
ST80 Planetary Focuser
Edited by maniack, 15 April 2025 - 11:50 PM.
  • T1R2 likes this
