The star is far too out of focus to really evaluate collimation. If you get much closer to focus, I assume that it'll will become obvious that the 10 o'clock position will be brighter than the 4 o'clock position. Note that as the star gets closer to focus, it will likely saturate. You will probably need to either shorten the exposure length or pick a dimmer star. In my opinion, just about any naked eye star will be too bright to finish collimation. When I collimate with a camera, I am usually using stars at magnitude 9 or 10.
Also, the center spot is not a star. It's a part of the diffraction pattern called a "Poisson Spot", and it is normal.
