Nikon just released an update to their NX Tether application that has support for Pixel Shifting on the Nikon Z8. I think this completes full support for remote operation of the Nikon Z8 and I can now see using NX Tether for all of my remote imaging when using the Nikon Z8. I think Nikon added pixel shift support to NX Tether for the Nikon Zf sometime last year, so it "only" took them six months to support that same feature on the older but higher-end Z8. The previous version of NX Tether could be made to work with pixel shifting, but you had to enable/disable that feature with the physical buttons on the camera and then when you initiated a shutter button press using NX Tether the pixel-shifted sequence would begin. Now you have full control of this feature with all of its options directly on the remote interface provided by NX Tether.
And before someone takes issue with this capability or asks about its use, yes, pixel shifting can have uses even for astrophotography. I've used it for both lunar and solar imaging and even for some wide-field DSO shots. You can treat it just like a fine dither operation and it does improve the resolution you get with the Z8. If done correctly and well it's almost like having a full-frame camera with a resolution of 180 mega pixels or a pixel size of about 2.17 microns. However, in most cases you'll have to use a drizzle integration to see the full benefits.
Edited by james7ca, 16 April 2025 - 05:03 AM.
