Everyone!
Many many thanks for all of your great feedback and insight!
bobzeq25
I am definitely looking into the 2600mm, however I will likely have to buy a new set of filters for it as my current camera uses 1.25” filters. Since I live in Bortle 6 skies, I will likely need a 3nm SHO set for it. ….and those types of filters can be a bit pricey. The 152 will definitely be the forever scope.
Rgsalinger
I have always heard a lot of good things about the 152 and the details on the photos it has produced is simply amazing.
Scadvice
That is an awesome ROR Observatory! I love the build and craftsmanship on it! The new scope will be housed in an Explora Dome in the backyard.
Dariv
The 140 is certainly in contention as a middle ground choice!
Mike Sandy
You make a very good point on this! Under ideal circumstances, I would want a Wide Field, Medium Field and Narrow Field setup. I ran the measurements for the 152mm OTA length and it should fit in the Observatory with just a smidge of wiggle room to spare. If I were to make any purchase, I would have to run measurements of the whole imaging train and auxiliary equipment to be absolutely sure on everything before I sink a small fortune into another scope.
SilverLitz
That’s not a bad idea to repurpose the 80mm. I may look into putting a reducer on it to bring it down to a f/4.5. If I did that, I may not need to install my RedCat51 as the wide field scope. …or I could install both as the mount (Paramount MEII) should have the capacity to handle quite a few scopes.
Overall the ultimate objective is to have a setup that contains a Wide Field Scope (RedCat51), Medium Field Scope (Stellarvue 130, 140 or 152) and a Narrow Field Scope (Celestron 1400HD). The only drawback is that I would have to move the camera depending on the target I would wish to target. I believe that my mount should be able to handle that kind of setup without getting fatigued so to speak.
I certainly have some homework to do! I believe that the SVX152 will be the best option as it will probably be a “Forever” scope….or until a Tornado hits the house. The weather in my area is always a crap shoot at any time of year!
Many thanks again everyone for your help, insight, feedback, suggestions and opinions! It is great to be part of this community!
