Two months ago, I changed telescopes from a C14 to a CDK12.5. I was using ASIAir but have switched to NINA and have really enjoyed the new scope with NINA. It sits on an AP1100. The camera train consists of:
• Hedrick Focuser->68mm wide extension tube->Wonderer Rotator -> Tilt Adapter -> ZWO OAG-L -> ZWO 7 2-inch filter wheel -> ASI6200mm
• I’ve used the spacers to get the correct back focus when the focuser is at ½ its range
• It all sits on a wheely bar that I roll out of my garage into the driveway.
Everything worked very well until last night. I could not get the autofocus routine in NINA (using NINA or Hocus Focus) to work.
The typical focus point is between 14600 and 14700. Below are screenshots of the settings I’ve used for the past two months; they have worked really well. The R-squared values are typically in the .9 - .97 range.
I also included screenshots of last night’s failed autofocus runs.
Initially, I tried:
• Checking to ensure no wires were caught
• Changing the filters used to focus
• Switching the camera to an ASI2600
I then used the PWI autofocus, and it worked. I noticed the default autofocus step size was 500, so I used this with NINA and Hosuc Focus, and it worked a greater percentage of the time. However, it still failed more times than not (with both Hocus Focus and NINA AF). I did not try re-using PWI autofocus, so I'm not sure if the one time I tried it and it worked was a fluke. I'll retry it tonight.
I don’t know what could have changed from one night to another. All I do each night is roll out the wheely bar about 10 feet and connect power.
I’m running out of ideas, sorry for the long post.
Any help would really be appreciated.
Phil
