There have been more than a few reports lately, of motor failures on Evolution mounts. Today, I had opportunity to dig a bit into these reports, with a disturbing conclusion. Read on!
At some point around 2020, Celestron began shipping Evolution mounts with the "Rev.K" main PCB (electronics) inside. And anyone sending an Evolution to Celestron for "repair", would most likely have received it back with a brand-new "Rev.K" main PCB installed. The Rev.K features the 3rd-gen WiFi revision for the Evo, along with other changes to the main PCB (electronics) of the mount.
One "feature" of Rev.K is becoming rapidly apparent: a high frequency occurrence of failures to the L293DD motor driver chip on the board. As in, a REALLY HIGH frequency of occurrence. Scour posts in these forums over the past 5-6 months, and you'll find a number of them. And these forums are only the tiny tip of a very large iceberg when it comes to owners/users of Celestron mounts, including the Evolution. Here is the Rev.K, Evolution mainboard:
A month or so ago, I acquired this Rev.K from another CN user who had experienced failure of the L293DD chip. They simply purchased a replacement board from Celestron, and sold me the "dead" one. I replaced the faulty chip here, and all was good.
Then, other users reported similar failures. And one of those users is from Ontario Canada, where I also reside. So I invited him to visit along with his broken Evolution mount. He had a different issue with it originally, and had sent it at great expense to Celestron for out-of-warranty "repair". They simply replaced all of the electronics with "new", including swapping his older Rev.F mainboard for a fresh Rev.K mainboard, and shipped it back to him. That's when the real problems began.
The "repaired" mount quickly failed, with one of the motors no longer responding. Dead L293DD chip, for sure.
So.. today, we finally got together. We opened up the mount, verified everything else inside was in great condition, and so removed the PCB to replace the dead chip. Fine. Reinstalled it, and then did an unusual thing: unlike Celestron, we actually tested it! We hooked up a StarSense AutoAlign, and told it to go ahead and do a full automatic alignment. Indoors, daytime, so it never actually succeeds, but keeps trying.
Now, StarSense AutoAlign is a bit different than a regular hand-controller alignment. When one uses a Nexstar+ hand-controller, most people slew in a single direction at a time, and then perhaps remember to slew back slightly using UP and RIGHT for final centering of an object. Whereas StarSense does it all by itself, slewing in both directions at the same time, and then quickly doing the UP and RIGHT at the end of each slew.
Within the first 30-seconds of the StarSense AutoAlign, the newly-replaced L293DD chip went.. POOF! .. up in smoke.
Crap. Bad chip, I guess. Having a bag full of them on hand, we just replaced it, again.
And.. within 30-45 seconds of testing, POOF! .. up in smoke, AGAIN.
One definition of insanity, is repeating the same action over and over, expecting a different result, despite strong evidence that the same result will repeat itself. Which in this case, it did. POOF! yet AGAIN!
Well, no problem, perhaps just a bad PCB then. So I got out the other, recently repaired Rev.K Evolution PCB, and we ran the same test on it. POOF! within 30 seconds. Whoa.. that's not good.
The first unit was running the latest 7.18.5028 firmware. The second unit was still on the older 7.17.0098 firmware. It made no difference. We repeated the test again, with a heat-sink added to the chip. POOF! Again.
It wasn't until much later, that I thought the evidence should be recorded, so I dumpster-dived into the trash can, and found most (but not all) of the discarded chips from our session.
Having fried more than a few of them, we switched to an older, Rev.F PCB, and ran the same StarSense "stress test" on it. After perhaps 30 minutes of no failures, we stopped it. This unbothered Rev.F board happened to be running the latest 7.18.5028 firmware , same as the first repeatedly failed Rev.K board.
Many mounts, not only Celestron ones, sometimes (rarely, but it happens) experience L293DD failures. But not like this!
EDIT: Update: Celestron are aware of this, and working on the issue. Hopefully there will be a firmware fix at some point.
Conclusions:
- Rev.K PCBs can quickly blow out the L293DD chip -- very easy to reproduce.
- Firmware version makes no difference.
- The older Rev.F PCB has no such issue.
Advice?
- If you have a Rev.K Evolution within its return period, wait for a fix, or RETURN IT.
- If you have an older revision that has a fixable failure, do NOT send it to Celestron for repair, because they may replace it with a Rev.K.
- If you don't yet own an Evolution (excellent mount, by the way), don't buy a new one for now.
EDIT: A particularly DANGEROUS aspect of these failures, is that the Evo has an internal battery pack, which continues to feed high-current to the PCB after the L293DD chip fails (POOF!). So the chip continues to burn and smoke internally for a while, and the battery continues to discharge at a high rate, until the battery itself finally dies. And without dismantling the tray area of the mount, there's no way to disconnect the battery to prevent this.
The "power" switch on an Evo does not actually control the power feed -- it's just a signal to the firmware to turn stuff on or off, which only works if the firmware is still up and running, which in this case it is not. And Celestron don't seem to have discovered protective "fuses" yet.
Edited by mlord, 18 April 2025 - 05:08 PM.
