Thought I would share a decent find ... a portable power pack that has actual >12V output (so not the Ni-XX varieties) with good capacity, for those times we just don't want or don't have an AC plug. A good example is keeping the 8 AA's in the NexStar8SE as a backup (to maintain settings) instead of being the primary power, while not having to lug a larger battery pack around when the session doesn't require it.
There was a sale going on at Amazon and sometimes a useful item pops up. This one was about $35. 6Ah capacity. Comes with cables for both 12V and 9V output ports, has a USB port, and a proper 14.6V LiFePO4 charger.
So I wanted to confirm the actual power cells being used and how they were managed. Decent system using 32700 LiFePO4 cells (at nominal 3.2V and 145g each) and a Cortex M0 MCU with 30V/30A MOSFETs for management.
If and when the cells get old, I suppose one could replace them with >6Ah units in the same 32700 form factor ... instead of just tossing the unit into the landfill.
There are several versions of this same thing, though this is the one that was on sale.
https://www.amazon.c...,aps,122&sr=8-5
