Tele Vue or Meade EP
#1
Posted 30 June 2004 - 04:10 AM
Which of these two eyepieces would be better for a 10" LX200GPS?
Tele Vue 32mm Plossl,
or
Meade 32MM 4000 Super Plossl.
#2
Guest_**DONOTDELETE**_*
Posted 30 June 2004 - 06:33 AM
Being a newbie myself I only wanted to say welcome. I’m sure you will get all the help you need from the more experienced members here – as I have.
Choosing only between those two I bet you will get a lot of recommendations to go for the Orion 32 mm HighLight plossl among others.
Of the series you actually mentioned I have only the 26 mm Meade that came with my scope, and I don’t think I’ll be getting any more of those with so many other options avaliable.
If you have loads of cash it’s nice to have the TeleVue logo on all your eyepiece boxes I guess.
The TV plossls are of good quality at a premium price if I’m correctly informed. The only TV eyepiece I have is a 16 mm Nagler T5 and it’s very nice.
#3
Posted 30 June 2004 - 07:14 AM
#4
Posted 30 June 2004 - 07:31 AM
Jarad
#5
Posted 30 June 2004 - 08:18 AM
#6
Posted 30 June 2004 - 09:11 AM
So your eye piece selection won't be critical unless you start owning faster dobs or refractors.
#7
Posted 30 June 2004 - 10:12 AM
#8
Posted 30 June 2004 - 10:30 AM
Bonzo
#9
Posted 30 June 2004 - 11:06 AM
As has been said earlier, for low power viewing in long focal length scopes the eyepiece does not necessarily have to be top quality to work well.
But if you plan to put it in a barlow then you may want to look at the Televue Plossl or similar quality eyepiece.
#10
Posted 30 June 2004 - 11:29 AM
#11
Posted 30 June 2004 - 12:09 PM
The reason for the choice being between these two is because they are both available on ebay and the TV is near its end date.
I don't yet own a telescope, I'll be getting the 10" LX200GPS (as mentioned) at the end of August.
After reading through a few posts from this forum, I decided to try to pick up a few eyepieces to have when I get my telescope. I've been bidding on ebay and up to now only had one winning bid, Meade 12.4MM 4000 Super Plossl.
Which other eyepieces would you all recommend for the 10" LX200GPS?
Thanks in advance.
Dave
#12
Posted 30 June 2004 - 01:52 PM
#13
Posted 30 June 2004 - 06:09 PM
#14
Posted 01 July 2004 - 05:12 AM
My gut feeling is that the 12.4 is probably the highest power you will want to go .
Hmmm...I bid for and won a Tele Vue 9mm Nagler on ebay last night, would this be a bad choice?
Dave
#15
Posted 01 July 2004 - 05:13 AM
Dave, I have a similar scope (8" SCT) and most eyepieces I have tried work well in it. Personally, I find with the long focal range of these scopes that a 2" diagonal and eyepiece in the 30 to 40 mm range helps to provide a wide field of view.
Thanks Victor, I'll look into this.
Dave
#16
Posted 01 July 2004 - 06:57 AM
I don't have that scope, or even that eyepiece, but if it doesn't work out well, the 9mm Nagler should be fairly easy to shift, as it's a popular eyepiece. Should be nice with a focal reducer....?
For initial question, I prefer Televue plossls in every focal length. Eye relief is more comfortable and view is slightly more "natural". In the 32mm focal length, as others have said, the difference will be marginal.
Enjoy,
Ant
#17
Posted 01 July 2004 - 07:44 AM
Dave
It's an excellent eyepiece, but with my skies it's not an "every night" ocular with a 2500mm telecope. Fairly often I'm limited to less than 250X.
#18
Posted 01 July 2004 - 09:36 AM
#19
Posted 01 July 2004 - 09:42 AM
Hi Dave, and welcome from another UK viewer!
Enjoy,
Ant
Hi Ant,
I've just got back from Scotland, spent a week in Edinburgh, nice place.
There is a f6.4 focal reducer on ebay, I have my eye on, I'll see if I can get it for a nice price.
Oh, I missed out on the 32mm TeleVue.
Dave
#20
Posted 01 July 2004 - 09:45 AM
From what others have said about Naglers, it's probably worth buying a small scope to go with it. A 9mm eyepiece in an f/6 refractor gives a very nice view.
I can see this is going to be a very expensive hobby
#21
Posted 01 July 2004 - 11:42 AM
#22
Posted 01 July 2004 - 09:36 PM
Dave
The 9mm Nagler is likely going to give you the highest usable magnification under the very best seeing conditions most of us mortals endure. But, as rboe said, the 12.4 is probably going to be the limit under most conditions.
#23
Posted 01 July 2004 - 11:00 PM
#24
Posted 02 July 2004 - 03:56 AM
Dave
