Hi (aka Star1Fun),
+1 on what (aka SeattleScott) said . . .
"People who buy Hyperions are more budget conscious and don’t typically have other options at the same focal length to compare against"
I have several Meade 8 inch SCTs (203mm x 2,000mm, f/10) and own the full set of Baader Hyperions. I also own the full set of Pentax XW which also 68 Degree Apparent Field of View (AFoV) eyepieces, but more premium than the Hyperions. Both provide 20mm of Eye Relief (ER) which I need because I wear corrective eyeglasses (for Astigmatism).
I believe (from what you have told us so far) the Baader Hyperion 10mm would be a good match for your SCT at a modest price point as contrasted with the Pentax XW 10mm which is about twice the price on the used market. The 10mm might be the upper limit of your sky at 200x or you might have better skies than me and Scott usually experience . . .
Bottom line: buy what you can afford and enjoy what you own . . . trade up when you can . . . eyepieces can be addictive . . .
Best,
Ed
P.S. there are other eyepieces out there at 10mm, but if you like the 17mm, you will like the 10mm as was already said in post #2 . . .
I also own Vixen LV Lanthanum 10mm and TeleVue Radian 10mm as well, but these are discontinued, so only available used . . .
Edited by eblanken, 20 April 2025 - 02:57 AM.
