DPAC - Stellarvue SVR80ST2 (2011)
3 replies to this topic
#1 Elusivephotons
Elusivephotons
  • Loc: 55* North
Posted 19 April 2025 - 09:53 PM
Well, I'm continuing on my DPAC journey and was able to run some tests on my Stellarvue SVR80ST2.  Aligning the focuser on this telescope was very finicky.  There is not much room where the FT draw tube passes through the collered flange.  I did get it really really close though.  One thing I've noticed is how touchy alignment is on all parts of the telescope.  I can see movement from just the normal brass compression rings slightly moving the final position of whatever you are using.  It's a wonder that anything stays 100% aligned at all times, lol.
I'm still working on my image taking, I'm having a bit of trouble with the LED 'shine' blowing out areas of the image.  It's tricky to get the LED's just bright enough to illuminate everything and not too bright as to blow out the lines.  You can see what I mean if you look at the outside focus (white) and see the bright spot, then compare to the outside focus (red) and the lines are blown out.
I've also switched to a lower LPI ronchi as I try my @Focus pictures.  If anyone can tell me how to position the ronchi lines when doing @focus images that would be awesome.  (ie. Do you focus in on a line, or the edge of a line, or the space between the lines?)  I ended up focusing so that some of the line was visible otherwise there was no definition in the image at all.  Not sure what's best here..
I also spent some time making this 'Results' sheet.  It's an excel file and I can share it with anyone that wants it, just DM me.
 DPAC - Stellarvue SVR80ST2 (2011) DPAC Results:
Link to PDF:  https://www.elusivep...PAC_Results.pdf
  • peleuba, Psion, mazdak and 7 others like this
#2 Elusivephotons
Elusivephotons
  • Loc: 55* North
Posted 21 April 2025 - 02:51 PM
Anyone care to comment on my results? I'm not the best at interpreting these yet. Obviously the more straight the lines the better.. but beyond that? This appears to be a decent lens/scope? No serious issues jumping out of these images?
#3 peleuba
peleuba
    Non-Metrologist
Posted 21 April 2025 - 02:58 PM
Overall the scope is a little undercorrected.  Looks smooth, too.  Not a bad little scope.
  • Elusivephotons likes this
#4 kgb
kgb
  • Loc: Orchard Landing Observatory, LI, NY
Posted 30 April 2025 - 09:35 PM
That’s weird, I followed this thread, but updates didn’t come up in my feed. Agreed. That is a nice lens. Excellent color correction and slightly under corrected. I I bet it gives great views.
